Steamed Turtle
- Apr 2, 2003
I'm trying to construct a watercooling and require some assistance. I've been doing some research for a couple days but I'm still very confused on some things. So I'll tell you what I do know in hopes of obtaining some assitance.
I'll first give you some background. I have a budget of about $200-250 to work with. I'm looking to watercool simply the CPU. My case is the Chemning 602, here is a picture of my case with everything in it to show you what kind of room we're working with. The case: http://xoxide.com/chenming6021.html. My case:
http://www.steamedturtle.com/myroom/5.jpg. I have an Antec TruePower 430Watt. This will be cooling a Athlon XP-M 2500+ on an EPoX 8RDA3+ Rev. 3. I am looking to have everything inside the case and I am not afraid to cut SOME holes, etc. If there's anything else you need to know, please ask.
Here are the parts I have picked out already. Suggestions are welcome.
Radiator: http://www.dangerdenstore.com/product.php?productid=1&cat=13&page=1 (Black Ice Xtreme)
Water Block: http://www.dangerdenstore.com/product.php?productid=32&cat=20&page=1 (Maze 4)
Pump: http://www.frozencpu.com/ex-pmp-09.html ( Eheim HPPS 12V)
Fan: http://www.frozencpu.com/fan-22.html (YS Tech 120x38mm Fan) Noise isn't a problem, this is actually 3dB quieter than the fan I currently have on my CPU cooler.
This is where you guys come in. I would like some help in picking out the rest of the parts. I don't just mean the main parts, to be completely honest I'm very, very new to this and don't know what I'm doing yet. I need to know everything down to the liquids, tubing, connectors, things to fill the system with. Thank you for your help, in advance.
