Building a system, opinions please
MotoMan756
Been lurking here awhile, and there is some excellent info here!! You guys are doing a great job.
This is my first build and just looking to be sure I am specing everything I should. I am at my money limit right now, but I am open to suggestions on any part:
SONY 16X DVD±R DVD Burner With 5X DVD-RAM Write Black IDE Model DRU120C
Newegg.com - SONY 16X DVD±R DVD Burner With 5X DVD-RAM Write Black IDE Model DRU120C - Retail
XION Onyx XON-303 Black/Blue Steel ATX Mid Tower Computer Case - Retail
Newegg.com - XION Onyx XON-303 Black/Blue Computer Case With Side Panel Window - Retail
Seagate Barracuda 7200.10 ST3400620AS 400GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Newegg.com - Seagate Barracuda 7200.10 400GB 3.5" SATA 3.0Gb/s Hard Drive - OEM
SCEPTRE X20WG-Naga Black 20.1" 5ms (GTG) DVI Widescreen LCD Monitor - Retail
Newegg.com - SCEPTRE X20WG-Naga Black 20.1" 5ms (GTG) Widescreen LCD Monitor Built in Speakers - Retail
Thermaltake W0106RU Complies with ATX 12V 2.2 & EPS 12V version 700W Power Supply - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16817153039
CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X2048-8500C5D - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16820145043
EVGA 122-CK-NF68-AR LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail
Newegg.com - EVGA 122-CK-NF68-AR ATX Intel Motherboard - Retail
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
Newegg.com - Intel Core 2 Duo E6600 2.4GHz LGA 775 Processor - Retail
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
Newegg.com - ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
Looking forward to what you all think. I will be using this system for some gamming, video editing, AUTOCAD drawing, and general purpose stuff.
theres no videocard listed there. And I'm assuming you would get one so theres no point in getting a sli board. Also becuase you are on a bugdet you should just get an E6400 instead which would save you another bundle this would go to your video card which isn't there :D. I would also change the case, but thats personal preference I would rather have tool less and maybe a removable mobo tray.
I'm too lazy to do the math. Whats your budget limit?
Also, drop the thermaltake and go for a corsair 620W instead -- much better psu.
$125 - Corsair HX Series CMPSU-620HX 620W PSU ($145 - $20MIR) (Free Shipping)
How fast do you plan on running that E6600? because 9*400=3.6Ghz... those dominators can OC to at least DDR2-1000, so 9*500 = 4.5Ghz... you got watercooling? I'm guessing not since you listed an ACF7Pro, so no need for such expensive ram. Go with ~$200 sticks instead, since 3.6Ghz is plenty, and pretty much the limit for these conroes with good air cooling.
$180 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
$207 - Corsair XMS2 2GB (2x1GB) DDR2-800 TWIN2X2048-6400 ($40MIR)
$250 - Patriot eXtreme Performance 2GB (2x1GB) DDR2-800 PDC22G6400LLK ($50MIR)
If you don't want to deal with raid, go for a raptor instead.
$190 - WD Raptor WD1500ADFD 150GB 10,000RPM SATA150 16MB Cache ($220 - $30MIR)
7950GT > 7900GT for almost the same price as the card you chose:
$235 - Albatron 7950GT-256 HDCP GeForce 7950GT 256MB ($35MIR)
$265 - eVGA 512-P2-N635-AR Geforce 7950GT KO 512MB ($15MIR)
Thanks for the reply, I think I will take your advise on the RAM and the video card, This will save me enough to upgrade the monitor to a faster/bigger one, I like that idea. I thought I was going overboard on the RAM I just wasn't sure, so I went top drawer. BTW, My budget is right at 1900, I am at 1950, so I am over as it is, but with your suggestions, I am now right where I need to be.
You don't think I will notice any performance difference w/the cheaper Corssair Ram?
Like I said, it depends on what you plan to run. If you plan on running 9 * 400 = 3.6Ghz, then no, you won't notice any difference. If you plan to run 9 * 500 = 4.5Ghz, then you'll have trouble with that ram and that freezer7pro.
BTW, the Corsair 620W has as much available amperage on the +12V rails as the Toughpower 700W, 50A. FYI, most of your system's power is drawn from the +12V rails. So, if you want to save some money, go for the Corsair... it will be more than enough to power your system.
I took your advise on the corsair as well, reviews on that unit are top notch!!
THANK YOU for all your help man, I should be ordering by the end of this week.
I am having issues on which MOB to choose here.....I think I am reading too many reviews lol. the one I listed originally seams to be a great board (EVGA 122-CK-NF68-AR LGA 775 NVIDIA nForce 680i ) but I have heard some horrible horror stories on this board as well as other places. Keep in mind this is my first build...ever. It doesn't scare me to have to mess with things to make it work, but I really don't want to get all this and then discover that I have choosen something that may be way over my head.
Any suggestions or am I just being paranoid?
id look at a cheaper ocing sli motherboard... no need to sped 250 bucks on that mobo however nice it is tho lol...
i think its mobos with the 650i chipset and 1 other one cnat rember off the top of my head...
You're just being paranoid. Every board has issues, some moreso than others, but thats all part of the fun in building your system. Getting everything to work. Like I said, eVGA will fix the problems sooner or later, so make sure you get the one with the lifetime warranty.
Thats pretty much what I have convinced myself of as well....Paranoia. lol
Ordering the whole thing later this week. Thanks again!
Everything is ordered from Newegg, should be here around Wednesday.
Thanks again everyone, I am sure I will have some more questions once I get everything.:cool:
