Building a skylake desktop.
Gaming and photoshop for personal use
800 USD before tax
CA, San Jose
CPU, Motherboard, CPU Cooler, RAM, Case
Storage: 1TB Samsung 850 EVO
PSU: Seasonic SS-660XP2
6) Will you be overclocking?
Yes. Hoping for 4.5G.
7) What is the max resolution of your monitor?What size is it?
24" 1920 X 1080
In 1-2 weeks
9) What features do you need in a motherboard? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0. Will not SLI definitely. Sata 6gps. Waiting on Pascal for GPU, Must have Intel NIC. Sufficient clearance for the CPU cooler.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes, 64Bit Win 7
PC Hound: https://pchound.com/LkWph4/
I am not so sure on Motherboard. I dont need SLI capabilities but cheaper motherboards may have worse VRMs that might not OC as well. I am considering the following.
Asus Z170 A
Gigabyte UD5
Gigabyte UD3
Gigabyte HD3
AsRock Pro4
Any opinions on the above MBs?
Thanks in advance
SO
