Building a shuttle
NFusion
Could somebody build me a shuttleX for around $800 that will used be used for games and such. Requirements are must include windows home XP and a AMD processor. Thanks for any comments or suggestions :cool:
Shuttle = 350.00 to 400.00
Good Gaming card: 200.00
XP Home licensed (full): 100.00
You see where I'm heading with this?
Good luck :D
can someone BUILD you one? i doubt it , we can tell you what to buy, and guide you into putting it together, but thats it heh
Good luck :D
Yeah I knew they were expensive but I thought there could be cheaper versions too.
I can build it myself I just wanted suggestions on parts.
ok this was made up all at newegg, its an AthlonXP system, this is as low as its gonna get, and its a nice system...
CONNECT3D ATI RADEON 9800PRO Video Card, 128MB DDR, 256-bit, DVI/TV-Out, 8X AGP -RETAIL
AMD Athlon XP 3000+ "Barton", 400 FSB, 512K Cache Processor - OEM
NEC 8X Dual Layer DVD+/-RW Drive, Model ND-2510A SILVER, OEM
Shuttle XPC Barebone System for Socket A at 400MHz FSB AMD CPU, Model SN45GV2
Western Digital Special Edition 80GB 7200RPM IDE Hard Drive, Model WD800JB, OEM Drive Only
Geil Value Series 184 Pin 512MB DDR PC-3200 WITH BLUE HEATSPREADER - OEM
thats 800$ EVEN! lol its perfect! (granted the prices stay the same hehe)
http://www.newegg.com/app/ViewProductDesc.asp?description=56-101-420&depa=0
SK43G 185.00 5 shipping
http://www.newegg.com/app/viewProductDesc.asp?description=27-106-932&depa=0&manufactory=BROWSE
LiteOn dvd/cd burner 44.00 1.50 shipping
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-341&depa=0
Athlon XP 2700 98.00 .99 shipping
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-449&depa=0
Corsair XMS 3200 1GB Ram 228.00 .99 shipping
http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-383&depa=0
ATI 9800 pro 190.00 .99 shipping
Hard drives are all your choice, 50-70 bucks for 60 to 80 GB drives.
$800 bucks for it all there. Not the greatest gaming system but for finding it all on New Egg within about 10 minutes isn't to bad. You can also prob. get different RAM cheaper if you look around but I've always had good luck with the XMS series.
Edit- XP Home about 100 bucks. Also if you shop around I'm sure you can get in your price range and do very well.
the KM400 chipset is garbage for gaming. my setupw as better, 512MB ram isnt going to hold him back.
