Building a new VIVO machine...
Jaxel
Hello... So my current computer is about 3 years old and the strain of video capture and encoding is starting to take a strain upon it. I've decided to build myself a new computer in the upcoming months. My previous computer was also built by me, but the advance of hardware over the past 2 years has come so fast that I'm making this post to make sure my hardware selection is a good choice and compatible with each other. Some of my choices here may seem odd, but I'll do my best to explain why I chose them. If you have recommendations for changes, I would be happy to hear them...
MOBO: ASUS Commando LGA 775 Intel P965 Express ATX Intel Motherboard
My old PC uses an Asus P4C800-E DX mobo and I've been very happy with it, so I'm going back to Asus this time. Why this Asus? The higher up Asus mobos cards are nForce SLI cards, and I plan on going with ATI Radeon. I also heard P965 is better than P975x.
PROC: Intel Core 2 Extreme QX6700 Kentsfield 2.66GHz 2 x 4MB L2 Cache LGA 775
Lets face it, I'm going to be doing a lot video editing. The more processors the better right?
RAM: CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
I'll live and die by Corsair XMS, this seems to be their best solution right besides their LED chips.
VIDEO: SAPPHIRE 100177L Radeon X1950XTX 512MB 256-bit GDDR4 VIVO PCI Express x16 CrossFire Video Card
Why this card over a GeForce? Simple. VIVO. I havent really seen any GeForce cards with VIVO with as high of a QoS as Radeon cards. I've been using Radeon cards to do my video capturing for a while now and I love it. I dont really plan many video games, so I dont need an 8800. However, this card is not HDCP compliant, is that something I should worry about?
OS: Microsoft Windows Vista 64-Bit Ultimate for System Builders Single Pack DVD
Why Vista x64? Various reasons. For one, I like the security advantages you get with Vista64 over Vista32. Secondly, I dont play many video games. Thirdly, if I ever plan on getting a YPrPb capture card, an x64 built computer is pretty much stated in all system requirements.
CASE: SILVERSTONE TJ09-BW Black Aluminum ATX Mid Tower Computer Case
Video encoding computers run 24/7, and they run hot. So I'm looking for a good quality, spacious and cool case. This case seems to fit the bill. I think I'll need to purchase some additional cooling solutions as well, so I'll take recommendations.
PSU: SILVERSTONE ST85F ATX12V / EPS12V 850W Power Supply 100 - 240 V RoHS, FCC, CE
I'm a little OCD, so neatness is a priority. This modular PSU seems to go well with the case.
As for hard drives and optical drives, I will be pulling those out of my old computer. Same goes with the speakers, monitor and other periphrials.
It looks like you just want the most expensive stuff. I'd drop to the P5B Deluxe or P5B-E. Switch to the the 4GB kit of DDR2 from g.skill. Wait for the R600 vidcards.
975X is crossfire, and can only reach around 450Mhz fsb, so a higher multiplier is needed for OC'ing (E6600+). P965 Express is better for the lower end chips because they have lower multipliers, and the chipset can reach 500+ fsb. So, if you want crossfire and are getting a higher end chip, the P5W DH is your best bet. If you're getting a lower end chip and don't need crossfire, then go for a P965Express board.
