Building a New System
RobAGD
Well my old faithfull Asus P2B-S has gone tits up.
I have been realy out of the hardware area for the last few years and I have no idea what the hot new lick is.
My main thing for my systems is stability, I dont OC typically, and the system will sit in a closet with 4 other machines.
I Will have 2gb of memory using Win2k or maybe Xp Pro, Some gaming will happen.
I typically go with Intel processors for my personal machines, as I was never super happy with the VIA chipsets for the AMD CPU's.
So What am looking for is a good suggestion on Motherboards. I dont do tons of upgrading so I would like something that going to have good long term processor support. I dont need a ton of stuff built in, USB 2.0, Firewire and 10/100 lan would be nice.
So What are your suggestion for a MB for building up this kind of system ?
-Robert
ABit IS7 gets the bang/buck here. Only $96
http://www.newegg.com/app/ViewProductDesc.asp?description=13-127-155&depa=0
And you get everything you want and then some. I've built 3 machines with this including my own (which is the IS7-G, other two were just IS7) and haven't had any problems at all. O yeah, the two IS7s I built machines around came w/gigabit LAN, not the 10/100 advertised. P4 3.2C is at a pretty good price point now too, and the 2.4C is as cheap as ever.
I've had crap luck with Abit boards. The nicest board in my opinion is the Asus P4C800-E Deluxe. You can also get it in standard form without the Firewire/RAID stuff.
Or if you want to save some coin go for the Asus P4P800 Deluxe/Standard which are i865 based instead of i875. The two chipsets are similar but there are some differences.
hm...
i'm planning to build a new system to
but i will used the dfi 865pe infinity
how about that mainboard
ASUS P4S800D-e deluxe. Fantastic bang for your buck, and outperforms intel chipsets when they're not completely identical in performance.
Thanks for the suggestions, I am still hunting around a bit but after reading a few reviews of a few Asus boards and given the good luck I have had with them in the past I am leaning that way. I wont get a chance to start buying everything for a week or 2.
I am still open to suggestions, something I havent really seen a lot of are Dual Processor setups, has that kinda died off in the "hobbie" market ?
-Robert
thats more for like if your running a crazy server, or do a ton of video editing(I think, I'm not sure about the video editing thing)
Well since Intel pulled true multiprocessing out of the retail market by making it so P4's didn't support SMP, pretty much.
And for multitasking P4's with Hyperthread technology kick ass anyway.
Asus has a couple of really attracking XEON solutions however. But your still paying a ton of money for the processors and boards. As stated before. unless your running a crazy server or doing some high end video editing and or 3d rendering for 3ds Max or Maya I wouldn't bother unless you just have money to burn.
VIA isn't the only choice for AMD processors anymore. NVIDIA is the other big contender in that market and their chipsets work very well. I would consider AMD again without the fear of the unreliable VIA chipset factor. The Athlon 64s are very powerful and well designed.
On the Intel side, if you are not going to overclock, you may want to go with an Intel brand motherboard (like this one http://www.newegg.com/app/ViewProductDesc.asp?description=13-121-180&depa=0 ) with an 875 chipset.
