Building a new system. Looking for some ideas.
dtess17
Well my current system is starting to show it's age, and is feeling a bit sluggish in games.
I don't see any point trying to upgrade it, it's an old socket 478. Had it for 3 years or so.
So i've decided that a new computer is in order. :D
I've pretty much decided that i will be making the switch to AMD and i will use the nForce 4 SLI chipset. But alot of the other details are still up in the air.
That is why i have come to post [H]ere. I am sure that you will all be able to help me build an awesome system.
My computer is used for gaming, music, video, photo's, and general work.
I don't want to go and break the bank on this machine so i'm thinking somewhere in realm of $1,500-1,700. I really don't want to go much higher than that.
I want a real nice powerful system, but I DO NOT want a loud computer!
Rather i want a very quiet kick ass computer. That being said i do not want to give up good cooling either.
MB: Asus A8N SLI Premium. I am pretty sure this is the board i am going to get.
CPU: Wide Open...X2 3800+? X2 4400+? something else?
RAM: I will use what is in my sig right now.
GPU: Again Wide Open...7800GT? 7800GTX?
HD's: WD SE16 250GB Sata II drives. Still open.
Audio: I will use what is in my sig right now.
CD/DVD: Wide Open
Case: Thought about an Antec P180 but this is still open. Needs to be cool/quiet would like 3 or more 120mm fans. Don't care about windows.
Power Supply: Antec NeoHE 550 90% sure i want this.
CPU HSF: Wide Open. Needs to be quiet and have better cooling than stock HSF (i might overclock).
GPU HSF: Wide Open. Same as above.
Fans, extras: looking for some great quiet fans that can still move a good amount of air. Nexus and Cool Master LEDs are at the top of the list.
Monitors and speakers will be taken from system in sig
Any thoughts comments and suggestions are much needed.
Thanks in advance.
here are my suggestions:
MB: Asus A8N SLI Premium (what u wanted)
CPU: X2 3800+? (you can always OC)
RAM: ur OCZs
GPU: 7800GT for under 1600x1200, 7800GTX for 1600x1200 and above (assuming u want all the candy)
HD's: Seagate drives for the silence
CD/DVD: anything from NEC, lite on, plextor, what ever is fine
Case: P180
Power Supply: Antec NeoHE 550 (though seasonics, are quieter)
CPU HSF: XP-120 with panaflo fan.. nice and quiet
GPU HSF: Zalman VF700-cu... in 5v mode its DEAD silent
Fans, extras: what ever u like, look at the DB and CFM ratings and make ur own judgement
Thanks for the quick replies.
I checked out the new A8N32 from Asus...although that does seem cool, you lose 4 sata ports. Which is bad and it looks like two PCI slots become blocked if i run SLI.
I don't think todays or even tomorrows GPU's are really even making use of the 8x bandwidth on PCI-E so i think i am going to go for the A8N SLI Premium.
I noticed you both went for the X2 3800+ any reson for that over the 4400+? wouldn't the extra cache be better ?
Also i've read that the Dual cores are having problems with games...and microsoft needd to release a hotfix that may not even be working....what gives?
I found this card i wonder with the out of the box overclock and awesome price tag...is it worth it to get this rather than the GTX...are the 4 pipelines really going to make that big of a difference ?
I think the reason everybody recomends the 3800+ is because, a) it's a lot cheaper and b) it can be overclocked to 4400 speeds with good cooling. I doubt if the extra cache on the 4400 is going to make that big of a difference. As for the issues you refered too..I haven't really heard of any. Dual core is slower in games than singe core, if you count ~10-20 fps as "slower". But that's only in games optimized for a single core. B&W2, as well as a couple others that are out now, are optimized for dual core. Many more games like that should be coming out as more people jump on that boat.
And yes, I would highly recomend that video card. eVGA is an excellent company, and the extra 4 pipelines of the GTX won't make a huge difference. And down the line you'll have more money to upgrade to SLI.
WD2500KS > 250GB 7200.8
The Barracuda 7200.8 has significant seek performance issues (Seagate has recently revised their seek time claim on it from "8ms average" to "11ms," and the noise profile settings on it are a crapshoot. In addition, WD2500KS is flat out faster, runs cooler, and is not a significant compromise on noise over the quietest Barracudas. If you get a 7200.8 locked in "performance" AAM mode, the WD drive may even be quieter.
Here's the rig I just assembled last week:
AMD X2 4400+ Toledo
Zalman CNPS9500 CPU cooler
2GB Crucial PC3200
2x250GB Seagate HDDs
Albatron 7800 GT
TDK CD-RW (from previous rig)
Sony DVD-RW (from previous rig)
Soundblaster Audigy2 ZS (from previous rig)
OCZ450 Powerstream PSU
LianLi PC-V2000B case w/2x120 Vantec Stealth fans and Zalman fan bus).
I went X2 because there are games coming out soon I'm going to get that make use of multi-threaded rigs (F.E.A.R, Quake IV, and Elder Scrolls Oblivion so I've heard). I haven't had any issues with games so far (DoomIII and Halflife 2 are the only ones I've had a chance to play so far). Doom III and Halflife 2 have been butter-smooth.
The Asus board I got mainly because of the heatpipe cooled Northbridge. It's very quiet (no whiney little Northbridge fans).
Went with 2x250 HDD to expand my mp3 jukebox so I can rip ALL of my CD's.
When I am idling, I turn all three fans down and it's VERY quiet.
Mr.Dearthian
AMD X2 4400+ Toledo
2GB Crucial PC3200
Albatron 7800 GT
Mr.Dearthian
Do you have any pics of all that installed in the case ?
doesn't the motherboard need to be mounted upside down for this case ?
You are correct about the motherboard orientation. I'll throw some up pics when I get off work.
Mr.Dearthian
I thought that flipping the MB upside down basically makes it so the heat pipe is useless?
I haven't been able to find any Asus documentation regarding orientation.
I wonder how having the heatpipe radiator back next to the rear exhaust fans affects normal heatpipe temps. Granted, my CPU fan is blowing right through it (which isn't going to help). This may affect my northbridge temps a little, but has thusfar not hampered the system stability (I am NOT overclocking). My northbridge temps average about 3C higher than my CPU at either idle or load. Since I don't overclock, this is fine with me as long as it's stable. I went with this board because I wanted quiet. Small Northbridge fans kinda kill this. If worse came to worse, I suppose I could turn my case upside down... :D
dtess17- Here's the pics you wanted. Forgive the wiring. Once I got my rig together, I only wanted game. Will I clean it up? Probably not. As long as temps are good and I have a solid case door... :D
It's hard to see, but the heatpipe feeds back to it's radiator between the CPU and rear exhaust fan.
Here's the drive bay.
Mr.Dearthian
yeah i've read that in some cases having your MB upside down with a heat pipe makes it not function right. I'll try and find the thread where i read that.
But anyways nice pics...looks like you built yourself a fine system.
Tomorrow i'll post my "first draft" of parts i plan on using, and see if i'm making any mistakes.
Ok i've done some thinking, these are my current plans.
AMD X2 3800+ (could still bump to 4400+ if money is there)
2GB OCZ Platinum
eVGA 7800gt oc 470 (two if money is there)
WD2500ks 250GB sata II drives.
Antec P180
Antec Neo HE 550 or maybe the 600 seasonic...not 100% sure yet.
Will get sound from my current pc.
buy some Lite On Dvd burners at some point.
Anyone that thinks there need to be any changes let me know...
also going to need something other than the stock AMD heatsink
Some people have said the Xp-120 what is the difference between that in the Si-120
What about the sythe ninja ?
any others ?
Looks good to me. For a cooler I'd recomend the Big Typhoon. Second would be the Scyth Ninja or XP-120.
RE: xp120 vs SI120--clearance issues on some motherboards. Look at the profile of the XP120---I have one, the fins come from the base, all the way up.
si210---the base connects to the Heatpipes, but the fins don't start until farther up the profile...less chance of interfering with any motherboard caps/sinks/fets.
For quiet air cooling, either the Thermaltake 120 series, or the Zalman 7700 series is the way to go. Note: the Tt 120s are much much lighter overall if you will be moving your case much and afraid it might come/fall off and damage anything. ;)
Looks like a nice system, have fun!
Quick update...might get rid of the X2 and buy when of the 100 series opterons
CD/DVD still open? Benq 1640. Crazy cheap, high quality (Plextor rebadges them). Probably the best DVD burner out there at any price, the fact that is well below $50 is icing on the cake.
Thanks i kinda forgot about my drives..I'll keep my eye on them. .Now i'm all caught up in the whole opteron idea...i might get the 148 if it overclocks well and i can find one.
