Building a new rig
Excko
Hi everyone,
I am building a new rig and I think I have it pretty much figured out so I thought I'd post it so I can get some additional input on it. It will be used mainly for gaming and I am going to do some video editing.
Here it is :
OS : Microsoft Windows Vista Home Premium Edition 64bit OEM
RAM: (OCZ Platinum XTC PC2-6400 4GB 2x2GB DDR-800 CL5-4-4-15 DDR2) x2
HDD: WD SE16 500GB SATA2 7200RPM 16MB Cache 8.9MS NCQ
PS : Corsair CMPSU-620HX 620W ATX Triple 12V 50A 24pin
GPU: EVGA E-GEFORCE 9600GT 650MHZ 512MB 1.8GHZ DDR3 PCI-E Dual DVI-I HDTV Out x2
MB : EVGA Nforce 750I SLI Ftw
CPU: Intel Core 2 Duo E8400 Dual Core Processor LGA775 3.0GHZ Wolfdale 1333FSB 6MB
CASE: ANTEC P182b
WRITER : Samsung SH-S203B Black SATA DVD+RW 20X8X16 DVD-RW 20X6X16 DL 18X/12X INT DVD Writer x2
I have a budget of roughly 1600$(taxes and shipping included) for the computer and about 400$(taxes and shipping included) for the monitor. I live in Canada and I will get the parts for online retailers.
As I said earlier, this rig will be used for gaming. I will play mostly MMORPGs like Warhammer Online and Age of Conan, but I also enjoy FPS and NWN2. I want to be able to push everything to the max and turn on all the eye candies for everything.
Odds are that I will be ordering a 4:3 monitor from dell and it will probably be a 17 or 19 inch. I will use 1280x1024 resolution. If I can convice the girlfriend I'll be getting a 22 or 24 inch widescreen so I'd also like the GPU to handle the resolution that goes with it without losing too much framerate and too much eye candy.
Also, I might get some of the new GPUs that are coming out in june if they are of a good price/performace ration instead of the SLI'd 9600GT.
I will keep this computer most likely for 3-4 years.
Any additional advices or comments?
Thanks.
I'd recommend the new WD 640GB Caviar SE 16. It uses 320GB platters and is nice and fast :)
SLI (and CrossFire for that matter) is not going to be worth the money unless you are gaming at 1920 x 1200 or higher. One 9600 GT will be fine for 1280 x 1024. If you do end up getting a 1920 x 1200 monitor, I'd suggest getting an 8800 GTS 512MB from eVGA or BFG Tech, and then use their Step-Up program in a month or two and get one of the new GTX260 or GTX280 cards.
Great motherboard for overclocking, even if you don't use it for SLI. I actually switched to this mobo from a Gigabyte X38 mobo, based on all of the great reviews I read about it.
I'd recommend a Q9450 and overclock it to 3.6GHz on that motherboard, but that's me :)
I'm purchasing a system similar to yours for playing Age of Conan, except I'm going with the recommendations I made above. The new video cards should blow away the current generation.
Do your best to get a 24" monitor, it's worth it :)
Definitely look at the new video cards.
That won't be a problem, especially if you go with a Q9450.
All opinions in this message are mine, and others may or may not agree.
