Building a new PC, need feedback.
DRJ1014
EDITED:
Motherboard
ASUS A8N32-SLI Deluxe Socket 939 NVIDIA nForce SPP 100 ATX AMD - $149.99
Processor
AMD Opteron 170 Denmark 2.0GHz 2 x 1MB L2 Cache Socket 939 Dual Core Processor - $189.99
Memory
CORSAIR ValueSelect 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) - $169.99
VideoCard
EVGA 512-P2-N635-AR Geforce 7950GT KO 512MB 256-bit GDDR3 PCI Express x16 Video Card - $264.99
HardDrive
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM - $89.99
SoundCard
Creative 70SB046A00000 7.1 Channels 24-bit 192KHz PCI Interface Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series - $140.99
PowerSupply
Antec NeoPower NeoHE 550 ATX12V 550W Power Supply - $109.99
CD-Rom/Burner
SONY Black 52X CD-R 32X CD-RW 52X CD-ROM 2MB Cache IDE CD Burner - $17.99
ComputerCase
LIAN LI PC-7B plus II Black Aluminum ATX Mid Tower Computer Case - $89.99
CPU Cooler
ASUS Chilly Vent Lux 80mm Sleeve CPU Cooler - $29.99
Monitor
SAMSUNG 941BW Black 19" 4 ms (GTG) DVI Widescreen LCD - $199.99
Software
Microsoft Windows Vista 32-Bit Home Premium for System Builders Single Pack DVD - $119.99
Total
1573.88
After looking at some of the items and prices my friend listed to me I decided to look around myself. I came up with this. What do you think? I have around $2000 to spend on a new computer (Full)
What changes would you make? What would you add? This computer will be used for gaming and school. Nothing too big.
Do you also need to get a monitor and peripherals and be within the 2,000 dollar budget? Or do you already have ones you can use?
If you don't need that stuff, I'm sure some people around here can recommend some really nice stuff for that budget.
What kind of case do you have in mind, by the way? And motherboard?
I probably can't help too much myself, but sure this information will help some of the really smart people who prowl around here.
Doh! Forgot to ask about the motherboard, Im currently an AMD man myself so I need some help with this crazy Intel stuff. I already have a monitor, speakers, mouse, keyboard etc. Case isnt that big of an issue and will not be counted into the budget. Just looking to get something running I can always change the case later on and upgrade monitors, keyboard, mouse etc.
But currently im just looking in the tower itself (Minus the case)
I'm using an Asus P5B Deluxe with an E6400 running at 3.2Ghz. It's a good board and I recommend it. If you're not looking to spend that much on a mobo, the Gigabyte S3 or DS3 are supposed to be very nice as well.
Change to DDR2-800 RAM, X1950Pro, 320GB Seagate 7200.10, and 16x Lite-On SATA burner.
$167 - Corsair XMS2 2GB (2x1GB) DDR2-800 TWIN2X2048-6400 ($207 - $40MIR)
$155 - His Hightech H195PRF256DDN-R Radeon X1950PRO 256MB ($175 - $20MIR)
$90 - Seagate Barracuda 7200.10 ST3320620AS 320GB 7200RPM SATA300 16MB Cache
$32 - Lite-On 16X DVD±R DVD Burner Black SATA Model SH-16A7S-05
Another good board, aside from the ones mentioned by wtburnette, is the P5B-E, along with the P5N-E SLI. If you need a cheaper solution, the Biostar TForce965P is also very good.
$100 - Foxconn P9657AA-8KS2H Socket T (LGA 775) Intel P965 Express
$105 - Biostar TForce965PT LGA 775 Intel P965 Express
$119 - GIGABYTE GA-965P-S3 Socket T (LGA 775) Intel P965 Express
$133 - GIGABYTE GA-965P-DS3 Socket T (LGA 775) Intel P965 Express
$140 - Asus P5N-E SLI LGA 775 NVIDIA nForce 650i SLI
$150 - ASUS P5B-E Socket T (LGA 775) Intel P965 Express
$180 - ASUS P5B Deluxe Socket T (LGA 775) Intel P965 Express
Your budget is $2000? USD or CAD? Because that system doesnt even come close to $2000USD.
USD. Was getting some rough estimates from a friend when he was giving me some ideas on what to buy. :|
Thanks for the info going to look at the stuff right now.
Bump for a lot of editing.
You went from a Socket-T Core2Duo to a Socket939 Opteron? :confused: You wanted less performance for your money? Socket939 has reached End Of Life, meaning AMD has already discontinued production. In other words, if you wanted to upgrade to a quad core later on, you'd need a new board and new ram. Socket 939 along with DDR ram is being phased out, but the parts you chose aren't much cheaper than their replacements. Here's some reading material:
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2903
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2802
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2795
http://dailytech.com/article.aspx?newsid=5414
The Intel price cut date is rumored to be April 22nd. Even currently, an E6300 would outperform an Opteron 170 for the same price, and the P5N-E SLI is under $150. Also, 2GB of DDR2-800 is the same price as those CS VS DDR-400 sticks. So basically, you're paying the same price for half the speed. Since you're building a new system, and with a great budget btw, you should really go for the best performance for your money; which would be a core2duo.
$184 - Intel Core 2 Duo E6300 Conroe 1.86GHz
$170 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
If you still want AMD, at least go for socket AM2, a Brisbane core CPU, and some DDR2-800 ram. You can use the same ram listed above. I'll let the AMD fans recommend a CPU/mobo, as I havent kept up with AM2 as much as Intel.
Also, $250 for a DX9 card? How long do you plan on keeping the video card? If you plan to play any DX10 games, then you'll need a new card. I say go for a cheaper DX9 card for now, until there are more DX10 cards available to choose from (only 2 right now). The ATI R600 should be out soon, along with midrange cards from NVIDIA. Now is the time to wait for a good GPU. If you don't plan on playing DX10 games for a while, I guess the 7950GT is ok. I think the X1950Pro would be a better choice (for your 19" LCD), though, so you can upgrade to a DX10 card sooner.
CD Burner? You don't want a DVD burner? They can also burn CDs :D
$140 for a sound card? what speakers do you have? if you're not an audiophile, then stick with onboard. FYI, Vista drivers for creative soundcards are terrible right now. It'll be some time before you can use your sound card. In the meantime, forego it and see how onboard HD Audio is. If its good enough, then don't bother with a sound card. If you think it sucks, you can always add in the soundcard later.
Awesome, looking at those now. Thanks for the input :)
