Building a new computer.
LaZyScV
I plan to do it in about 3, 5 weeks . . . depends on when I get enough money.
I already have a case, which is a Gigabyte Poseidon
(The abbreviated sections to the parts are the model numbers; makes it easier to find on NewEgg and the like)
CPU: Intel Core 2 Duo E6600
GPU: eVGA GeForce 8800GTX (768-P2-N831-AR)
SC: Creative X-Fi XtremeGamer Fatal1ty Pro (70SB046A00000)
Ram: 2x1gb Corsair XMS2 Dominator DDR2 800 (TWIN2X2048-6400C4D)
MB: eVGA 680i SLi (122-CK-NF68-AR)
PSU: Cooler Master Real Power Pro 850W (RS-850-EMBA)
HDD: Western Digital Caviar SE16 320GB 7200rpm 16mb 3gb/s SATA (WD3200KS)
CD/DVD: 2x NEC 18x DVD+/-RW 8x DVD+/- DL etc (7170A-0S)
Total of about $2000.
Basically, only thing I am unsure about is the ram and the video card. Should I downgrade because of the better DX10 coming out later on . . . since the current ones are huge and hot (and so are the soon to come out ones, excluding die updates of the 8800 series).
I am considering getting the 1950XTX; $200 less, and which is not a big performance drop from 8800GTX.
Plus ATi, or, rather, AMD drivers are supposed to be a lot better; from what my friend told me, the newer nVidia drivers still make his windows media player (10 or whatever the newest version is) unusable. I am still using an old nVidia driver for my video card because of that happening to me, but that was quite a while ago, when they first introduced that new interface . . . I do not know if it still does from my own experience.
If I go the ATi way, I have no idea which motherboard I would get, so suggestions there would help if I should.
Oh, and I plan to get a Westinghouse LVM-37w3, so the resolution of gaming will not be that high, just 1920x1080. If I do not get that, I will get a 24" monitor, which would be around the same resolution, so.
And this is my current PC, which blows harcore and I built about 4 years ago (was on a $500 budget):
AMD AthlonXP 2200+
eVGA GeForce FX 5200
2x Kingston 256MB PC2700
ASUS A7N8X-X
a 52x CD-RW
60gb HDD
And so on.
nooooooooooooooooooooooooooooooooo!!! Why are you buying Nvidia when the new ATI are about to come out?
Hard to forecast anything 5 weeks from now.
Some new Mobos are getting ready for release in the next 2 weeks or so.
Price drops expected in Q2
More variety of cards will most likely be available.
etc
As of Now ATi Crossfire would be on Intel Chipsets
Nvidia SLI on 650i, 680i chips.
