Building a new computer soon, need some help please...
Hey guys, building a new computer soon and really need some help. I'm aiming for a mid-range so nothing too crazy. I've never overclocked before but I would like to try with the new Core 2 Duo CPUs (maybe around 3.0-3.2 GHz on air cooling if possible). I usually upgrade a complete system once every 5-6 years, so currently I'm on a P4 2.2 GHz.
I know some of what I want, but I need help with the other items. I figure it's better to post here than to post a separate thread in every single forum. I'll just list out the specs below and the ones with question marks are the things I need suggestions on. Thanks in advance for the help :)
Processor: Intel E6600
Motherboard: ???
Memory: ??? (2GB for now, plan to do 4GB in the future)
Graphics Card: ???
Hard Drives: 1 WD Raptor X 150GB, 1 Seagate 7200.10 320GB
Display: Dell 2407 or BenQ FP241 (Opinions on this?)
Heat Sink: Tuniq 120 or Thermalright Ultra-120 (Opinions on this?)
Power Supply: ???
Case: ??? (Whatever this is I need to make sure it will fit the graphics card)
Soundcard: Creative X-Fi XtremeMusic
That's about it. Thanks in advance for the suggestions/help :cool:
you need to give us a budget. your idea of mid range is not the same to others. give us a dollar amout not to exceed and you should get some feedback
Oops, didn't realize that. Sorry.
I guess my budget is around $2500 for everything. I'd like to keep at or below that, but if it's slightly over it's alright.
Please don't include the soundcard as I already have it.
Case-lian li PC-1000
http://www.newegg.com/Product/Product.asp?item=N82E16811112118
Monitor benq
http://www.newegg.com/Product/Product.asp?item=N82E16824014124
Gpu- eVGA GTS
http://www.newegg.com/Product/Product.asp?item=N82E16814130071
You may want to consider a GTX with that monitor, but I really don't think it should be necessary; I'll wait for other opinions.
so, OR
http://www.newegg.com/Product/Produ...02&Submit=ENE&Manufactory=1402&SubCategory=48
PSU- corsair 520
http://www.newegg.com/Product/Product.asp?item=N82E16817139001
RAM- corsair
http://secure.newegg.com/NewVersion/Shopping/shoppingcart.asp?submit=view
The same ram as the ones with the XXXXXXTREAM headshields
If you don't plan on doing a lot of overclocking there is even more money to be saved here as we can go with a lower speed of ram.
Mobo- eVGA 680i
http://www.newegg.com/Product/Product.asp?item=N82E16813188009
There are a lot of mixed reviews on this mobo, so I also recommend the Gigabite. If you don't think you'll be going SLi, there is even more money to be saved.
Other mobo- Gigabite
http://www.newegg.com/Product/Product.asp?Item=N82E16813128323
Rock solid, good overclocker, good all rounder.
CPU- 6600
http://www.newegg.com/Product/Product.asp?item=N82E16819115003
that brings you too 2480 on the egg with
- 40 from that if you do the mail in rebates
Thanks for the suggestions :)
I do not plan to SLI or XFire, although being able to upgrade later or having the option would be nice.
Do you guys think the Raptor is really worth the money? I don't consider myself a heavy gamer, but I do play some games and some MMORPGs. So the computer will be used for some games, surfing internet, chat programs, and Word/Excel for work.
I like the 680i for the chipset, but I'm scared about all the incompatibilities I've been reading about. I like things as simple as possible... I can't be bothered to return and try all different types of RAM just to get it to work with the mobo.
Do I really need a $200 case? I was hoping to get away with a case in the low $100s.
I really want the computer to be ready for Vista and last me a good 4-5 years without upgrading if I have to.
Thanks again for all the suggestions, look forward to hearing more
OK so which motherboard should I go with?
I don't really know the technical differences between P5B-e, P5B Deluxe, P5B Plus, Asus Commando, Striker Extreme, etc.
Which RAM do I go with? Seems like a lot of poeple here like the G-Skill and the Corsair Dominator series. I will probably go with DDR2 800 but should I get one with a fan or no? And what is this Micron 9 thing I keep reading about? How can I make sure my RAM has it?
Oops forgot one thing. I like the idea of getting a bare minimum graphics card for now until more DX10 cards come out. What's a good and cheap card that will at least run some games on a 24" Dell? I have an ATI X800 sitting around but it's an AGP card. Will that work with any of PCI-e motherboards or no?
Since you have the money for it, go for the raptor. I'd go with the 74GB raptor and the 320GB seagate (or any other 7200.10 seagate drive). My raptor gets about 78MB/s avg transfer rate, while my Seagate 320GB does around 65MB/s avg... and my WD2500KS (as well as my WD1600JS) does around 55MB/s.
The Antec P180B is a nice case, too, but I don't think it'll fit a GTX (nor am I sure about the Antec Nine Hundred). Go with the Cooler Master Stacker :cool:
Since you don't want SLI, go with a Gigabyte GA-965P-DS3 or Asus P5B-E. Actually, since the DS3 is now the same price, go with the Asus, since it has more features, lol. Here's a side-by-side.
$150 - Asus P5B-E Socket T (LGA 775) Intel P965 Express
$150 - GIGABYTE GA-965P-DS3 Socket T (LGA 775) Intel P965 Express
Good decision on the vidcard. I'd go with the X1950Pro. No, an AGP card won't work on any midrange/highend Core2Duo board (only on lowend boards, using via chipsets).
$156 - eVGA 256-P2-N624-AR GeForce 7900GS 256MB ($176 - $20MIR)
$170 - Sapphire 100176L Radeon X1950PRO 256MB ($190 - $20MIR)
$200 - eVGA 256-P2-N636-AR GeForce 7950GT 256MB ($215 - $15MIR)
$220 - Sapphire 100186L Radeon X1950XT 256MB ($250 - $30MIR)
Thanks for the post!
The P5N-E SLI is actually cheaper than the P5B-E and it uses the 650i chipset. Would that be a better buy then?
So many choices on the video cards... I think i'll go with the X1950PRO like you said or the 7950GT.
Monitor benq
Gpu- eVGA GTS
so, OR
PSU- corsair 520
RAM- corsair
Mobo- eVGA 680i
CPU- 6600
Everything looks good here, but i would go with a Dell Ultrasharp Display
I think I will get the Asus P5N-E SLI for my motherboard as I like the Nvidia chipset but I don't really need the 680i. Pair that up with the E6600 and some nice RAM I should be able to get some decent overclocks right?
I've already ordered the Tuniq Tower 120 and Dell 2407 monitor. Still haven't decided which RAM but I think good RAM will always be a good investment. I think I will go with a Silverstone TJ09 case.
Also, do you guys recommend the ATI side or the Nvidia side for a medium range graphics card? I just want something that will get me by on a Dell 24" monitor and run simple games like CS:S and WoW until more DX10 cards are available. It doesn't have to run it at highest settings, just medium or so will be nice.
Finally, is there going to be a price drop or significant changes to the E6600? I will probably buy the CPU and mobo in late Feb. I am spending my time now researching and buying the other parts.
Thanks!
This is some decent ram for the price. I've used it in several builds, and have had no problems booting up. It usually reaches around 450Mhz (DDR2-900):
$210 - G.SKILL 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
Here's more info on Q2 intel roadmaps:
http://dailytech.com/article.aspx?newsid=5414
Oh, and the X1950XT is nicely priced to feed a 2407fpw, hehe.
Why not something faster? For a 2500usd budget build I'd expect some higher shelf ram...:confused:
Wow, I must be mixing up threads 'cuz I could have sworn I recommended the ballistix or firestix in my earlier post, lol... I agree, though, you should get some better ram. Go for the Crucial Ballistix DDR2-1000 or Buffalo Firestix DDR2-800 kits. They both have the Micron IC's that can OC very well.
I went ahead and ordered the Corsair HX620W and the Crucial Ballistix DDR2 6400 memory.
I know it's stupid but after looking at the Asus P5N-E SLI I don't really like how it looks. What are my other choices if I want to go with the 650i chipset?
I'm still torn on what to choose for hard drives as well.
Maybe the EVGA, BFG, XFX and Foxconn 650i boards are coming out soon?
Personally, I love the 680i.
I'm pretty scared of the 680i due to all the problems people have been having. Plus I don't think it will fit with the Tuniq Tower 120 that I'm going to be putting on it. The backplate hits the resistors or something like that...
