Ok, here is the deal. I need some help making a choice. I am building a new comp for my family that is going to be used for basic applications, web browsing, etc and occasional gaming (like Sims 2 or Wow, not HL2). I am going to use the XFX GeForce FX 5700LE, and 1GB of Mushkin DDR 400Mhz PC3200 that is dual channel capable. The HD will be a 200GB Maxtor. The motherboard will be the K8 Neo Platinum. Now the choice is with the processor.
I am definitely going with the AMD 64 3000+. I am trying to decide between the newer socket 939 Winchester 90nm and the socket 754 Newcastle 130nm. Price is not a factor as the difference with the 754 mobo+cpu and the 939 mobo+cpu is <$50. Neither is the fact that the Socket 939 board will be more upgradable, as I won't upgrade for a while
after this (well, it's a factor, just not much of one)
I want to OC the cpu to around 2.2Ghz-2.4Ghz. I heard that the Newcastle can give better performance once OC'd even with the 800Mhz HT bus, since it is just a crippled Clawhammer. But the socket 939 Winchester offers dual channel memory and a 1000Mhz HT bus and runs cooler. It also takes 128bit DDR SDRAM, but I only have 64bit anyway. Plus the mobo for the 939 is a bit nicer.
My question is, which will give me better overall performance (both OC'd and stock)?
Thanks in advance for your help.
