im building a computer and i need some pro advice on what i need and why. this is a list of what i am planning on getting. if you see that something wont work with what i got or know of something that would work better for same price or cheaper tell me and why i should change it what benifits. i have done some research on things and im going to have my brother help build the computer for me i dont know much about compuers but i know enough to use one very well i just cant build one for crap. anyway this is what i have so far.
Case. thermaltake xaser armor series va8000bws
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=371253 $140
ppl said that there is ENOUGH room in there and have had no real problems other then the screwless design of it but easly solved with screws
or the
antec performance I p180 silver
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=140118 $120
they said where the power was located is the only problem with it. i like it cause i will keep my equipment nice and cold while running it. but kinda hard to build which i dont have a problem with cause my bro will build it for me
i dont know which one to get but iv narrowed it down to those two. which one tho and why?
CPU the amd 64 3700+
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80719-5 $215
good chip that runs cool but stock heatsink suckes if your going to over clock it which it will be over clocked alittle ohh im sticking to AMD no matter what cant change me to intell
hard drive western digital WD2500KS 250GB 7200 RPM 16MB Cache
http://www.monarchcomputer.com/Merc...duct_Code=150939&Category_Code=SATAHardDrives $110
all computers that i have iv gone western digital with 250gb that is PLENTY enough and its got a 16mb catche and cheap but still WD
MOTHERBOARD asus Socket 939 ATI Radeon XPRESS 200 CrossFire
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=247035 $120
this is the one that i have been looking at. i havent really went with any other MOBO other then asus is there a better one out there from the reviews people have had some problems with it this MOBO help input please
CD DVD plextor PX-740A/SW-BL
http://www.monarchcomputer.com/Merc...&Product_Code=160145&Category_Code=cdrw-dvdrw i can get it for $83 at newegg
i heard that plextor made a killer 18x writer somewere out there in the world called the px-76a but i dont need anything like that. dont really know much about writers i know plextor is good tho is there a better one cheaper or same price that i should change to
MEMORY 2gb corsair
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80097-55 $240 200 after rebate
timeing of 2-3-3-6 running 2.75v
Video Card Radeon X1600 PRO PCI Express 512MB DDR2
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=326835 $200
even tho nvida has kicked radeons ass in some equil tests i am still a firm beliver in radion
this seems to be a really good card that can do alot. the card might get a little hot but im not worried about that cause theres going to be enough airflow in the case that it might take off.
power pac
i havent done much looking around at what i need to power this rig but somewhere around the price range of 000 to 160 is all i think i want to spent here
the total would come to around 1100 but im still missing things. like a sound card and lan card cables ect and if i missed anything improtant do tell
due to work hours and all the things that i have to do i most likely wont be able to reply untill the weekends. i plan to get the computer together within the month. i need advice on where or if im messing up and how what do i need to fix it. i have come close to how much i wanted to spend on this cause i am shooting for 1100 the way it looks this computer will last and run games well on past for a long time with minor upgrades. my last computer i built lasted for 4 years and still runs games VERY well with only 2 upgrades on it.. videocard to a 128 card and ram to 2x512 i hope that this computer will be able to live up to my hopes. but with advice on what i should do im sure it will be able to do so much more.
thank you proud member of the US millitary
or the
MEMORY 2gb corsair
power pac
