The title doesn't really tell you what I am doing I plan on taking my old psu,gpu,hdd,mobo, cpu,ram,monitor getting a case cheap one a dvd cd player burner and make a comp for my brother and family they will get the old stuff while I get the new hehe.
old stuff is a
CPU
AMD Athlon 64 X2 4600+ Windsor 2.4GHz Socket AM2 89W Dual-Core Processor Model ADA4600CUBOX
MOBO
ASUS M2N32-SLI Deluxe Wireless Edition AM2 NVIDIA nForce 590 SLI MCP ATX AMD
RAM
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400C4x2
PSU
ENERMAX Liberty ELT620AWT 620W ATX12V SLI Certified CrossFire Ready Modular Active PFC Power Supply
GPU
XFX PVT71UZDF9 GeForce 7950GX2 1GB 512-bit (256-bit x2) GDDR3 PCI Express x16 HDCP Ready SLI Supported Xtreme HDCP Video
HDD
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s
Monitor
It is a 21 inch wide screen LG flatron 2000:1 contrast ratio 5 ms recovery rate nice screen I may keep this and use an old crtv for the old build and this screen for my new build make the build cheaper.
3 year old stuff what I will be getting to finish this off to actually make it run is irrelevant.
New build I am at a lose as I have kinda not looked into new parts gpus and so on in 3 years made new comp never looked back kinda thing.
I have a 1.5 tb hdd 2 dvdcd burner drives and a COOLER MASTER CM Stacker STC-T01-UW Black/ Silver Aluminum Bezel, SECC Chassis ATX Full Tower Computer Case witch is really huge this will be for the new build maybe I might get a diffrent case and use the cmstacker for the old build not too sure so lets say I will just use the drives.
I am striken between AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core and intel i7 920 looks good but don't know the advantages and disadvantages of the two I would like to get better upgradability this time for future upgrades like change of cpu ram increase and gpu maybe even dual monitor or triple monitor in the next 2 years.
I need advice on intel and amd and I have very little time to do so less than one month to do this as I will be moving I would like suggestion on cpu, mobo, ram, gpu, and power supply (and whats the benefits off a sound card suggestions on this on too). I do a lot on my comp I have a budget of 1100-1500$ US dollars plan to get as much as I can from newegg if not all or maybe microcenter witch is close to me I would like to keep it in the 1100-1500$ range if at all possible nothing more then 1500 would be nice to be less.
Sorry for any grammar punctuation spelling and if their are any misunderstandings I am sorry and will fix that or re post an explanation.
old stuff is a
CPU
MOBO
RAM
PSU
GPU
HDD
Monitor
