I've decided to create a HTPC that will be used as a media center that is controlled via remote to play dvds, record and play tv shows, play music, etc, etc. I will have some decent startup money to spend on this in the immediate future, but it is definately a budget box.
Here is the current system I have for this:
--IBM Netvista case and 90 watt psu. Case is too small because it only allows half height PCI cards and does not allow you to use more than one ram slot with the motherboard im using.
--Radisys/Eudora P810 motherboard, accepts fc-pga, ppga, and tulation (yes, all three!) celeron and p3 socket 370 chips up to 1.6ghz. Has two sdram slots (max 1gb total) for ecc or non ecc ram, has 4 PCI slots, and has onboard video and sound. This board was originally aimed at being a small cheap server board but has great desktop use. Extremely tiny and awesome in that it is FlexATX and still has 4 slots! This board has no agp slot which is a pain, but not a real problem.
--Celeron 600/100 fc-pga 1.5v, not the greatest chip but you cant beat $6+ shipping for it. Lowest voltage of all the celeys in this range, runs amazingly cool with a small heatsink and extremely low speed fan.
--128mb PC133, running at 100mhz of course since the bus speed is 100mhz. I would like to upgrade this if I keep the mobo/cpu but I don't know if I will.
--16x BTC dvd-rom drive, got it on clearance for $9.90 and didn't have any other use for it so I placed it here. Not the quietest drive but not bad at all to start with.
--45gb/5400rpm Maxtor hard drive, noisy for a lower speed drive because it was one of the first ones of this size to come out and apparently noise wasnt an overall concern.
--NIC that has been cut up a bit to fit a low profile slot
The current system can do the following:
1. Surf teh intarweb
2. Thats about it
How I plan on upgrading:
1. Replacing the case. Right now i'm leaning towards the black TRT-100 for $53 or the Cooler Master ATX-620C-BX1 but i'm open to other options. What i'd really like to find is a nice low cost desktop case that looks good on an entertainment center and has full height PCI slots. Kind of a general statement, but it's to the point.
2. Getting a video card with tv-out. I am leaning heavily towards a GF4 mx420/440 with tv-out simply because they can be found cheaply in both PCI and AGP versions and have good quality tv output (the ones that use the on-chip encoder AFAIK)
3. Getting a TV tuner card with hardware encoding. I am under the impression that my current cpu/mobo/ram will be sufficient if I don't have to do any software encoding, and I am willing to go as far as buying a 700-933mhz P3 for it, but I don't want to change the whole combo unless absolutely necessary. That would be an upgrade for later on. The card i'm looking at is the Hauppauge PVR-250 retail, it has hardware encoding of MPEG-2 and excellent quality according to most reports i've read. Apparently this is the card to buy for the money.
4. Controlling everything by remote. I am under the impression the remote from the PVR-250 is compatible with at least a few of the major TIVO-ish programs out there, so there shouldn't be any problem using it for full functions.
5. Getting more ram. I don't think 128mb is going to cut it, and sdram is cheap.
6. A decent soundcard will come later on, maybe an audigy or TBSC, nothing major right away, onboard sound will be ok until this is up and running.
What I would like to know:
Any of this sound good? Opinions? Advice? Thoughts? I've been doing a lot of reading and it sounds fairly straightforward!
2. Thats about it
