Building a Game Pc *UpDated
angryzoo
This is my current list
eVGA 768-P2-N831-AR GeForce 8800GTX 768MB GDDR3 PCI Express x16 HDCP Video Card - Retail
EVGA 122-CK-NF68-AR LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
i need a hard drive and memory and im done any suggestions are welcomed my left over budget is about $300
If you can swing it go for a WD Raptor as your primary and maybe a seagate .10 hdd as your secondary.
Memory, case, extra cards? What do you have already? It is hard to make suggestions without knowing what you have and what you are eyeing up ;)
$58 - Seagate Barracuda 7200.9 ST3160811AS 160GB 7200 RPM SATA300 8MB Cache
$80 - Seagate Barracuda 7200.10 ST3250620AS 250GB 7200RPM SATA300 16MB Cache
$95 - Seagate Barracuda 7200.10 ST3320620AS 320GB 7200RPM SATA300 16MB Cache
$110 - Samsung SpinPoint T HD400LJ 400GB 7200RPM SATA300 8MB Cache
$170 - Western Digital Caviar RE2 WD5000YS 500GB 7200RPM SATA300 16MB Cache
$195 - WD Raptor WD1500ADFD 150GB 10,000RPM SATA150 16MB Cache ($225 - $30MIR)
$185 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
$225 - Patriot eXtreme Performance 2GB (2x1GB) DDR2-800 PDC22G6400LLK ($265 - $40MIR)
$245 - Buffalo Firestix 2GB (2x1GB) DDR2-800 FSX800D2C-K2G
$290 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400PHU2-2GBHZ
$300 - Crucial Ballistix 2GB (2x1GB) DDR2-800 BL2KIT12864AA804
I was looking at the exact same three components today on Newegg.com. Would really appreciate some recommendations.
Preferrably, I'd like to wait to see what ATI announces later in February, but with my current (old) build showing its age and frequently having random hardware errors I'm really leaning towards upgrading now. It's been going for 3 years and I only upgraded the video card last spring, but it's now finally time to go pci-e.
Right now I'll need to upgrade:
AMD 64 3200
Abit KV8-Max3 (one of the sata banks is already toast, and the board constantly gives me problems ... the otes shroud, the annoying fans, and the siren alarm have been the bane of my existance for years)
eVGA 7800gs AGP
1gb DDR ram
Antec TruePower 430
I'll be able to recycle:
WD Raptor 74gb (primary)
Seagate 320gb .10 (secondary)
WD Passport 120 (portable)
Antec P180 Case
2 DVD-RW drives
Soundblaster Audigy
Logitech G15+G5 Combo
Dell 2407 Monitor
Over the years I've grown tired of dealing with Abit/Asus, and after a good experience with the eVGA card (and all the recommendations on this forum) I think I'll stick with them for the board. Don't really plan to overclock much, so I'll save some money on the ram. What I really need is a setup that will leave me well positioned to run the new DX10 games in 1920x1200 on my monitor.
CORSAIR XMS2 DOMINATOR 2GB (2 x 1GB) 240-Pin DDR2 (combo discount at the egg)
PC Power & Cooling Silencer 610
Keeping system noise down is a big concern for me, and I'm hoping these parts will mesh well together. I can get everything for just under $1600 from newegg not counting $70 in rebates, and it seems fair to me. Any glaring problems that anyone can see?
Thanks.
Heh, thats why I stay away from VIA chipsets (personally, unless its an ecs board that basically comes free with CPU purchase from Fry's, lol). I also don't recommend them unless its the only viable option.
XMS2 Dominators? Thats not saving much on the RAM, lol, even with the $15 discount. Go for the KVR667D2K2/2GR or F2-6400CL5D-2GBNQ instead. If you want silence, go for a Seasonic S12 or M12, or the Corsair 520W or 620W instead (also made by seasonic). Also, go with a Scythe Ninja Plus Rev.B for the CPU cooler (for silence).
So your total comes to...
$1596 + tax and shipping - $70MIRs = $1526 without tax/shipping
And this would cost... ~$85 less
$316 - Intel Core 2 Duo E6600 Conroe 2.4GHz
$250 - eVGA 122-CK-NF68-AR Socket T (LGA 775) NVIDIA nForce 680i SLI
$129 - Corsair HX Series CMPSU-620HX 620W PSU ($144 - $15MIR) (Free Shipping)
$560 - eVGA 768-P2-N831-AR GeForce 8800GTX 768MB ($590 - $30MIR)
$1486 + tax and shipping - $45MIRs = $1441 without tax/shipping (you could save $40 more if you go with the kingston ram listed above instead)
Now take that $85 and get one of these:
$40 - Scythe SCNJ-1100P 120mm CPU HSF
$47 - Zalman CNPS9500 AT 2 Ball CPU HSF
$55 - Thermalright Ultra-120
$60 - Zalman 9700 LED 110mm 2 Ball CPU Cooler
$65 - Tuniq Tower 120 P4 & K8 CPU Cooler
Thanks for the reply. I actually ordered the above config last night only to read more about buzzing noises on the eVGA 680i capacitors and cancelled. I'm probably never going to SLI and might do some modest overclocking, but I want the most rock-solid board possible after dealing with Abit and Asus boards for so long. So now I'm really considering the Intel Bad Axe 2 ... assuming it will have great build quality and next to no capacitor squeal.
Noise is a big issue with me, so thanks for your heatsink recommendations. You'd recommend the Corsair PS over the PC Silencer?
Ordered the Corsair PSU from Zip Zoom and about to pull the trigger on the rest of the items from Newegg.
Here's my setup and if anyone has any last minute suggestions/concerns I'd love the advice. Figured going with the stability/minor overclocking of the Intel board would be a good idea, and it doesn't seem to have any of the noise issues that some are having with the eVGA 680i.
Intel C2D E6600 CPU --$316
Intel BoxD975XBX2KR (Bad Axe2) Motherboard -- $247
OCZ Platinum Rev2 2GB DDR2 800 -- $194 with rebate and combo deal
eVGA 8800GTX -- $570
Scythe 1100P - $40
I've heard good things about the retail intel HSF and am wondering if I should bother with the Scythe. I have two 120mm fans over the CPU in my P180 case and it might be completely silent with the Scythe though, so I'll include it.
*edit* just noticed that Microcenter has the same motherboard for $200 shipped 2-day with tax. Will then just get the GSkill Ram recommended above and not have to bother with the rebate. Seems like a good deal.
Looks good.
Thanks for all the help enginurd. I ended up ordering everything from Newegg ... they've always been reliable, and when I mentioned the huge price disparity on the bad axe 2 board the online help agent knocked some money off my total bill to bring everything closer. Plus they've already shipped everything, which is a plus.
Strange that zipzoomfly hasn't shipped the Corsair PSU yet. Ordered it in the morning with 2-day and it's still stuck processing. Hope it ships in time to arrive with all the newegg stuff.
Thanks again.
np... zzf usually ships same night, too. i guess they're busy :confused: The last couple of orders i've had from both the egg and zzf have all arrived the next day, lol.
