unimatrixzer0
- Dec 22, 2004
Basically planning on building a file server to record directly to or move TV captures. Also to save torrent downloads directly to. At most, no more than 2-3 devices at MAX would ever try accessing this server at any given time. I could have it downloading torrents and recording or streaming TV captures at the same time.
I don't want to be to cheap on the parts but I also don't want to over speed on muscle I probably wouldn't need. What would you recommend for a CPU? Something dual core.
For some basic parts I was thinking of WD 500GB hdds. Probably 2.5TB so 7 drives at the most which includes the hdd with the OS. How many watts should the PSU I buy have?
I'm also a bit confused about raid 5. I know if I keep adding more 500GB hdds the size will keep increasing by that amount. I also know if I were to pop in a 750GB hdd that it would only use 500GB's of that. But what would happen if one by one I replaced all the 500GB's with 750's? Would I have to basically start over and format all the drives to take advantage of the 750GB's or would raid 5 automatically enlarge?
One of my friends just uses the SATA ports on his ASUS mobo and I believe linux for a software based raid 5. Does windows xp support raid 5 or would I need windows 2003 server? Are there better third party application raid software that are windows based?
Is there any reason for me to go with a hardware based raid card vs software for the uses I mentioned?
Thanks.
Thanks.
