Ice Czar
Inscrutable
- Jul 8, 2001
Putting a little database together of the power draw of assorted esoteric devices
and Id really appreciate it if the [H]ard could contribute information if you know it.
Pumps
anyone running a H2O system and knows the amp draw their pump pulls would post it, this is just for DC pumps
Make and Model w\ its rated amps
if you know the actual amps its drawing at a given temperature (ambient case)
because youve measured it will a multimeter by all means post that as well
but note that its a realworld measurement and the case temp please
(or the coolant temp if its submerged)
Lights and Transformers
all makes and models
Baybuses, or other controllers, relays, servos, ect
both custom and stock items
Unusual Fans
have a few databases for fans, but throw a link for anything you might have as well
or unusal fans, like crossflow
Im putting together a definative guide to working up realworld numbers on powering different configs in the PSU Forum, and these arent "common" items on any calculators
any contributions saves me the initial research
Thank You
Pumps
Unusual Fans
Thank You
