charlesshoults
- Mar 18, 2008
I have a reloading table, measuring 60" wide, 33" deep and about 32" tall. The four legs are made from one 2x6 and one 2x4 each. At the table top height, 1x4s are used to join the four legs together. A second set of 1x4s is used to create a platform about 10" from the floor. I plan to expand each, so that they can be enclosed to create 8" high storage cavities, hoping to get rid of a small book case I have in the same room. A portion of the upper cavity will be used to hold a computer, built into the table. The table top is built from a pair of old office desks that my company gave away while remodeling part of the building. I'll be picking up a Mountain Mods motherboard tray and will be looking for methods of keeping the computer dust free.
My first thought is to use positive pressure. The Mountain Mods tray has mounting for a single 120mm fan. That fan, plus the power supply will make up the only exhaust ports. For intake, I'm planning to use 4-6 120mm fans, and on the outside of the fans, hope to use a 20" x 20" paper air filter, pulling air from the bottom of the table top, so shouldn't be able to pick up any standing dust or dog hair (two Labrador Retrievers sleep in the building where the table currently sits). For drives, I'm going to get a 3x5.25" drive bay cage from Mountain Mods and will probably fit it with a four bay SATA cage. The motherboard configuration I'll be using is a 3.2GHz socket 478 P4 and 2GB of ram. Ubuntu or XP Pro? Undecided. My old 19" monitor will be set toward the back of the table and input will be through a wireless keyboard/mouse combo.
Would four intake and two exhaust fans be enough to maintain a positive-pressure system? Probably. A better question might be, is a large air filter going to create too much air restriction for a computer to keep cool?
