thegloaming
- Aug 12, 2004
Hey guys,
Two years ago I came to HF when I needed help building my first custom PC. The assistance I received was so exceptional, I decided I would return whenever I needed additional help. Well, the time has come, my friends, and I'm sure you won't let me down this time either.
My dad needs a PC for a modest price in order to run a single program: RealFlight G3. Here are the minimum/recommended specifications for the program:
Now, just because he claims he'll only need it for a single program, I don't want the machine to be so bare bones that it'll lose all utility if he ever needs to run anything else. Also, because, I don't want him to have a miserable time trying to get the game running under the minimum specs, we should frame our options based on the recommended specs.
It might go without saying, but he'll also need a license of Windows. Taking that out of consideration, he doesn't really want to spend more than $300. $200 would be more ideal, but I'm almost certain that is just too low for what he needs.
My plan is to listen your guys' input on components to buy over at NewEgg and then compare the final price with a pre-fab arrangement and then weigh the costs and benefits of each option. Basic economics at work, people!
As I've stated before, I can't do this without the help of the community. So please, if you have any suggestions, don't hesitate to respond. And, while price is important, I want to get a realistic number here, so suggest products you feel will fill the recommended requirements.
Thank you for your time and support.
- thegloaming
Minimum
Windows XP, 2000, ME, 98
Intel® Pentium® 1.0 GHz or equivalent
DirectX 9 (or above) feature-compatible video and sound card
3D accelerated video card with 32MB (or more) RAM (e.g., Nvidia GeForce 5200, ATI Radeon 9600)
256 MB RAM
1.3 GB hard drive space
USB Port
Optimum
Windows XP
Intel Pentium 3.0 GHz or equivalent
3D accelerated video card with 128MB (or more) RAM (e.g., Nvidia GeForce 6800, ATI Radeon 9800)
1 GB RAM
USB Port
- thegloaming
