Building a comp, need to know which processor to go with?
vertigofm
Ok I've budgeted about $350 for a new CPU (is that too low or just right?) and it's been so long since I've read up on processors and I need to know... Intel or AMD and specifically which processor? I need an awesome processor, I love gaming. And, I like the idea of overclocking so thats always a plus too. But I really dont know crap about processors or which to go with, I want an awesome one and I'm trusting you guys to steer me in the right direction. Thanks as always,
Frank
AMD Athlon X2 3800+
or
AMD Opteron 165
Both dual core processors and great for overclocking. Games are starting to use more dual core now.
If your going to overclock them probably the Opty 165 if you can find one. However, if you have problems the Opterons are not officially supported on any motherboard (aside from server boards) so you will be out of luck unless you have another S939 processor.
so I should probably go with the 3800 huh?
Yeah, I'd go with the 3800+ just for the simple fact it runs 200MHz faster stock than the Operton 165 (albeit with half the cache per core). I wouldn't worry about the cache though, as having two cores as opposed to just one either way would probably outweigh having more cache when running apps and playing games anyway (for apps and games that are SMP capable).
