So I have a deep thought question. I am looking for a new AMD system. Preferrably dual core. I want to game on it some, nothing much though. I want to spend less than $1,000 and I need to be able to pvr, not necessarily MCE though. I can get either this system from Gateway:
http://www.gateway.com/home/products/ret/ret_gt5032.shtml
Or
NEC Black IDE/ATAPI DVD Burner Model ND-3550A - OEM
COOLER MASTER Centurion 5 CAC-T05-UW
Western Digital Caviar SE WD1600JS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive -
Gigabyte GA-K8NF-9 Socket 939 NVIDIA nForce4 ATX AMD Motherboard - Retail
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card - Retail
COOLMAX CP-500T EPS12V 500W Active PFC Power Supply - Retail
CORSAIR ValueSelect 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200)
AMD Athlon 64 X2 3800+ Manchester 1GHz FSB Socket 939 Dual Core Processor
Microsoft Windows XP Home With SP2 - OEM
BFG 6600 PCI-Express - OEM
The Gateway would cost $869+tax and the one I build would cost me $975 total.
Advantages of the Gateway:better processor, bigger hard drive, dual dvd drives, Windows MCE, quieter probably.
Advantages of mine:easy to upgrade when i want to, power supply a lot better, video card better than integrated.
What should I do?
Or
What should I do?
