Droc
- Mar 20, 2007
Browsing, media server, light gaming
$500-$750
Canada/Ontario
4) What exact parts do you need for that budget?
Mobo, CPU, ram, GPU, possibly CPU heatsink
5) If reusing any parts, what parts will you be reusing?
Antec P180, HDDs(WD blacks), 500w powercolor PSU, thermalright ultra 120 extreme push/pull
6) Will you be overclocking?
Probably not
1680x1050 I run two 22 screens but only game on 1.
Within the next 2 months
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Nothing specific
Win7 64
I thought I was done with PC gaming and was going to ride my old core2duo into the sunset, but after many years its really showing its age.....and I got the itch for BF3
I dont really have the budget for a full build, nor do I really need it. I thought I would look into just grabbing an old Q6600 but its impossible to find. and any GPU upgrade will be bottlenecked by my PSU and slow ram.
Looks like im stuck with a half build at least. I figure Im fine with my current case, screens, HDDs, and possibly CPU cooler.
Im looking for a budget build thats half decent but as cheap as possible.
$500-$750
Canada/Ontario
Probably not
Nothing specific
Win7 64
