Build problems with new i7 860 system
bob5568p
Hi all, Here's my current build.
Gigabyte P55A-UD4P mobo
i7-860
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRH - Retail (All x2 for 8GB of system ram)
Item #: N82E16820231279
Cooler Master Intel Core i5 compatible Hyper TX3 Socket 775/1156/AMD 130W 92mm "heatpipe direct contact" CPU Cooler RR-910-HTX3-GP - Retail
Item #: N82E16835103064
Assembled into an older case with a 520 watt Crucial PS, and older cdrom/dvd
Current harddrives are loaded with 32 bit XP - Full backup has been made to an external hd
New 64 bit windows 7 installation is to be part of this build
OK...Wierdness number 1:
In spite of the nearly inscrutable instructions on assembling the Cooler master hsf bracket and fan, I strongly believe I assembled it correctly.
The system posted fine, and the fans were spinning. I was part way thru setting up the bios, when the system shut down. After a bit of trial and error, I found the cooler master 92mm fan was only spinning for a second or two, and then it was stopping. Of course, then the cpu did a thermal shutdown. HOPEFULLY not becoming damaged in the process.
I replaced the cooler master hsf with the default one that came stock with the i7. It spun just fine, and the computer appeared to work ok. I assume this means the mobo, and power system is working ok. Assuming the 92mm fan was just defective, I brought it to work (Engineering firm) with the idea of buying a replacement at lunch. We put 12vdc onto the fan, just for fun...and it spun just fine. I don't know how the sensor and pulse circuits work, so I didn't look into it any more. Running full speed, this was one quiet fan.
Question 1: What problems would be mine if I just clipped the leads for the sensor/pulse, and just ran the fan full out?
Question 2: Anyone have experience with a cpu going into thermal shutdown. Is the CPU able to recover completely undamaged after reaching that temp (perhaps 90C?)
Wierdness #2:
Once I re-installed the stock hsf, I was able to proceed with setup. Once the bios was setup, I put the 64bit windows 7 dvd in the cdrom, set the bois to boot from cdrom, and booted. The screen displayed black with a white progress bar at the bottom, and the text, "Windows is loading". Ok...seemed fine, however, once the progress bar reached the end, the screen never moved on to the next phase.
I wonder if the problem is the presence of 32bit xp on the hard drives. I wonder if 64 bit windows 7 would install fine if I offered it a virgin harddrive. ( I have several, I was just going to setup a raid 0 for work data later once things were up and running.)
Question #3: Anyone else have any issues like this when installing 64 bit windows 7 over a prevsious 32 bit xp?
Thanks in advance for any thoughts!
"Question 1: What problems would be mine if I just clipped the leads for the sensor/pulse, and just ran the fan full out?"
A: The fan should be able to run at full speed for years without problems or buy a better fan that has a working sensor. If I were you I would use the stock HSF and send your TX3 back for a working replacement.
"Question 2: Anyone have experience with a cpu going into thermal shutdown. Is the CPU able to recover completely undamaged after reaching that temp (perhaps 90C?)"
A: I have seen a HSF fall off a friend's computer (C2D) and it shut down. Once he installed a better HSF it ran fine without any problems. It still running strong today.
"Question #3: Anyone else have any issues like this when installing 64 bit windows 7 over a prevsious 32 bit xp?"
A: Sounds like you might have a upgrade only Win 7? I just built a I7-860 rig and installed win 7 64 ultimate on a new HD just fine. If you have another computer you could reformat your HD and then try installing Win 7 again. If anything else you could install another windows and then upgrade it to Win 7. <---- last resort.. Although as far as I know Win 7 64 bit will do a clean install unless it is over a Vista 64 bit.
-- Also check to make sure all your settings in your bios are correct. It could be locking up on you during the install. Ram settings seem to be the biggest issue for new builds.
Hope this helps
Thanks for your responses. Most helpful, I will reformat the hd and try again. I do have a vista license I never used, but that seems cludgy...so I'm going to try to avoid that.
AFAIK, the ISO that's present on the Windows 7 disk isn't differentiated by upgrade or full. The CD/Product key is what establishes which version you are installing. However, when you install Windows 7, it notes whether another version of Windows in installed, and so when you use the upgrade key, it uses this information (which it stores, even though you may format the drive) to allow the Windows authentication to occur. If it doesn't see that a previous version was installed (or you didn't directly upgrade from another OS, like Vista 32 -> 7 32 or Vista 64 -> 7 64), and you try to use it, the key fails.
I've done a XP 32bit -> Windows 7 64 bit upgrade. I had to boot from disk (putting the disk in and trying to start the upgrade from Windows 7 caused an error saying my disk version was incompatible from the installed version), and the process went seamlessly.
