I was wondering how hard it is to upgrade a PC to a new motherboard. I have a Lian-li aluminum case that I would like to keep but scrap everything else. I could buy a mobo/CPU combo kit from somewhere and put it in my case--nforce4 and athlon64. However, I know nothing about putting a mobo into a case. I don't know where the rises go or anything like that. Is this stuff easy or should I leave it to the professionals? Same question with putting in a PS (I'd probably get an ultra x-connect).
I really have no problem with buying a different PC so I'm leaving that as an option also. Is it really that much more expensive? Who are some builders you would recommend? I've looked at Monarch and Cyberpower but would like to stay away from the overpriced "super" builders like Voodoo, Alienware, Velocity Micro, etc..
