Build opinion plz kthx
I'd probably build something like that, if I weren't being needlessly excessive. Awesome build IMO
I'm a big fan of Antec's cases, but I do not like their PSUs. Go with PC P&C, FSP, OCZ, etc. The Antec will probably suit you fine (some of their PSUs are cheap and flimsy though), but at that price you could look into some of the previously mentioned manufacturers.
I wondering if I am choosing the right ram. I haven't seen much conversation on here about PC9600 RAM and wondering if I am making the right choice or am I supposed to get some PC6400??
help here plz
No need for DDR2-1200 with an E6600. Stock speed is DDR2-533. The highest you can push that E6600 on good air is around 9*400=3.6Ghz, which is DDR2-800 speed. Intel platform performs best on a 1:1 ratio (it doesnt scale as nicely as an AM2 system, lol). DDR2-1200 is 600Mhz, and I dont even think the P35 Express boards can reach that high yet.
Drop the X-Fi if you're gonna use Vista.
What size monitor do you have?
Using XP until Vista gets it shit straight. and I have a 22" Widescreen running @ 1680x1050
help here plz
PC6400 fo shure
I would recommend G.Skill
Great Overclockers: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231114
Excellent Overclockers: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231065
I would spend the money saved from the memory on a better PSU:
Corsair HX620: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139002
And personally, I would grab the raptor off of the FS/FT thread for much less w/ a warranty. Very much worth it IMHO. That's just my $0.02
thx for the help guys, really lost when it comes to ram changed so much in 4 years, lol.
I agree with alik's RAM suggestions. If you want to save even more money, go with these:
$85 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
I've used these in over a dozen builds, and they work great. They can even be OC'd to about 425-450Mhz! Timings can't really go lower, though. The lower CL4 latency on the PK sticks won't be noticeable in every day usage (~3% performance improvement). However, the HZ sticks for $115 are a steal, especially if you need good overclockability. But again, with an E6600, you don't really need to OC DDR2-800 ram.
