These parts I would get but you should note that in the next following months the next cpu and videocards will more likly be out but anyway you should look into...
CPU: AMD64 FX-60 Dual Core 2.6Ghz.
Motherboard: Asus AR832-MVP Deluxe (If you want to go with ATi's Crossfire)
or
Motherboard2: Asus A8N32-SLI Deluxe (If you want to go with Nvidia's SLi)
RAM: Corsair TWINX2048-4400PRO
Videocards: ATi Radeon X1900XT PCI-e(x2)
or
Videocards2: Nvidia Geforce 7900GTX PCI-e(x2)
Soundcard: Creative Soundblaster X-Fi Elite Pro
Harddrives: Seagate 500GB Sate 2 Drive/s (x2)
Case: Coolermaster CM Stacker 830
or
Case2:Collermaster Ammo if you want to take it to lan's easily
PSU: FSP Epsilon FX700-GLN (Really good PSU, defiantly get if you go SLi or Crossfire or still get it even if you dont right now)
That's about what I could think of, a PPU card is only for games to reduce the workload on the cpu of the pyshic's, and if you go with those videocards I suggested then it really comes down to what you like that most because those cards are basicly neck and neck.
I would personaly go with Crossfire because it is good.
I could be bother trying to find the prices for everything because I have to go now, and I would wait for more suggesstions.
Those rams are good, and yes 4GB total is going to make Maya and Photoshop render faster and run smoother but games is alittle to much (until future games come out that require more ram has usual).
Vista is being delayed to Q1 2007 so its a long wait and Xp programs and games should run on it,the price I dont know about because there are 7 different versions of it coming out.
*edit*
I forgot, how well are you at using Maya and Photoshop because I am starting to get in those programs and I would like to get has much of help has I can so can you please send me a pm.
Intel is very behind in the current cpus. Currently Intel is making a huge deal about the upcoming Conroe dual core cpus that are coming out at the end of this year. They are making such a big deal about it because they are trying to turn the attention away from how poor their processors perform compared to the AMD X2 dual core cpus. That being said the enthusiasts are really looking forward to these new Conroe chips because preliminary benchmarks show that Intel will become competitive again in performance.
So if you want a computer now an AMD X2 is the way to go, if you're willing to wait until the Q1 2007 then the Conroe will most likely be the way to go. I say Q1 because there are always bugs and bios issues with new motherboards, so you'd want to wait a little bit and see which motherboard is the leader.
The FX-62 is currently the fastest stock AMD cpu, and it's faster than anything Intel currently has. If you don't want to pay the price premium for the FX-62 look at the 4800+ it's also dualcore and runs at 200mhz less and will overclock easily back up to the X2 speeds and you save $400+.
SLI or Crossfire is hard to say. You should chose based upon which performs best in the games you want to play.
