[Build Log] Mil-Spec
B NEGATIVE
It seems my SR2 build has drawn some attention :thumb: and as a result i have been contacted by a friend wanting me to build him a nice gaming rig for his son for Christmas.
So i specced him a nice machine that can play games all day long for a reasonable price.
So......the specs......
Intel Core i5 3570K,1155, Ivy Bridge, Quad Core, 3.4GHz, 5 GT/s DMI, 650MHz GPU, 6MB Smart Cache, 34x Ratio, 77W, Retail
Asus Sabertooth Z77, Intel Z77, S 1155, DDR3, SATA III - 6Gb/s, SATA RAID, PCIe 3.0, DisplayPort/ HDMI, ATX
3GB EVGA GTX 660 Ti Superclocked+, 28nm, PCIe 3.0, 6008MHz GDDR5, GPU 980MHz, Boost 1059MHz, Cores 1344, w/ Backplate
Corsair Vengeance C70 High Airflow Military Green Mid Tower Gaming Case with Side Window USB 3.0 2x120mm Fan w/o PSU
750W Corsair Pro Series Gold AX750, Modular, 90% Eff', 80 PLUS Gold, SLI/CrossFire, EPS 12V, Quiet Fan, ATX, PSU
Corsair H100 Hydro Series Extreme Performance CPU cooler, S775/1155/1156/1366/2011/AM2/AM3
120GB Kingston HyperX, 2.5" SSD, SATA III - 6Gb/s, SandForce, MLC-Flash, Read 555MB/s, Write 510MB/s, 85k IOPS Max
1.5TB Seagate ST1500DL003 Barracuda LP, SATA 6Gb/s, 5900rpm, 64MB Cache, 8ms OEM NCQ
120mm Corsair Air Series SP120 High Performance Edition, High Pressure, 2350rpm, 62.74CFM, 35dB, 3-Pin, Twin Pack
Corsair Memory Vengeance Green 8GB DDR3 1600 MHz CAS 9 XMP Quad Channel
The case is having some minor modding done,panel swap for a clear window with no fan mounts,lights....all your favorites.
This is not going to be a drawn out log,this will be turned around in a week or so.:thumb: (EDIT:maybe a bit longer as there is a loop going in after all)
Nice little gaming rig i think,You?
So,a little picture deluge i think,no need to explain anything yet as its all at the basic stage of things.
Now we start to get the modding trousers on...
Start simple i think,i dont want to detract from the chrome goodness coming......
So,you know whats coming...time to get the pipe benders back out!!
The H100 is going,i have a custom loop going in so more copper hardline!
Just a small update...
My friend came round yesterday to have a look at the progress and to deliver a second 660Ti.
So,while the rig was out of the box,i installed the OS and got myself ready for doing the loop when the final bits arrive from XSPC.
And Yes,there will be a Sli cover going on that ugly ASUS bridge.
More progress.....
Front panel roughed out before final filing
360 rad test fit.
Rad painted and fitted and pipe work set out.
Still needs some alignment tweaks but this is the routing.
D5....of course.
Fitted and filled.
So all i have left to do is the front panel paintwork,the last bit of wiring and tidying and choose what fluid to run.
I am actually enjoying working on small cases again!
The interior is finished and the loop is bled.
Front panel is done,just need to do the final cut on it.
All i have to do now is a reasonable OC on it and install all the bits and bobs.
She is gone,its back with the Dad......there is a empty hole in my life (and more space in the 'lab')....
I have something much better coming,Mark has said that he and his boy will do a video of him unwrapping it.
Much nicer than rig shots,i get to see his reaction as its him that im trying to impress.
I am quite looking forward to it
I will be doing a LAN box for myself i think....MilSpec II....I owe me it i think.
awesome work. I really like the colors you went with. I wish someone would buy me a computer like that!
That's one lucky kid.
Yeah, the color Corsair went with is killer. Really nice spartan/utilitarian look to it!
I love the copper lines. When done right it just looks awesome.
Even more gangbuster, I actually think those are stainless. Or the lighting is deceiving and they are in fact copper. Either way, so awesome.
