Build log for Watercooling
Im looking to Water-cool my 2x evga 680 classified cards. Also my cpu.
I will give you all my current set up. I would like to rebuild in the same case.
Cpu: 3570k @ 4.5hz
Mobo: P8z77-V
Cpu Cooler: Corsair H110
Psu: Corsair Hx 1050
Case: Roswell BlackHawk Ultimate
Gpu: 2x Evga 680 Classified
Now tbh my temperatures are pretty good. Under Prime 95 my cpu will not go over 48c
And my cards under load are around 50-71c depending on the game. I have a push pull config on the Radiator for the cpu using Noctua fans. All the case fans are filled with bitfenix 140mm fans. I have them all controlled with two fan controllers so its never really loud. I have always wanted to fully watercool my system but i have really no idea where to start getting a list of parts i need. I would want to drop the corsair H110 all togather and have one massive loop between the cpu and gpu with two big ol radiators. If i need to get a diff case im thinking about the Mercury S8 for full moddular awesomeness..
http://imgur.com/8Br3GSX
So did you get anywhere with this?
In a previous build I had a 3930k with 2 GTX 680s all cooled by a 240mm x 25mm radiator and a 240mm x 60mm radiator. My GTX 680s never broke 40C at full load.
I still have the waterblocks if you are interested.
