Next month or two? Can you narrow down that time-frame any further? If not, please come back when you're 1-2 weeks away from buying the parts and ask for advice then. That way you'll get up-to-date advice.
With that said, your planned setup is not good at all:
- That motherboard is beyond overkill for your needs.
- That video card is too weak for your needs
- That 500GB hard drive and PSU are both bad for the money you're spending
- The high-speed RAM is not necessary at all. DDR3 1600 is all that you need.
