Stupid_Newbie
- Dec 4, 2005
Hey guys, I have been out of the loop for a while now. I havent been keeping up on my hardware at all. And my current rig is on its way out. So its time for a new one. Its about 8 years old.
Asus P4C800DLX
P4 3.0C
1024MB OCZ Plat DDR400 2-2-2-5
ATI X850Pro (flashed to XTPE)
80/250GB WD Cavier ATA100 7200RPM HDDs
Cheap Case
Audigy 2 PCI
Lite-on CDRW
I also have an HP HDX18 1180CA Laptop I mainly use now
Here is the 10 Questions to start:
1) What will you be doing with this PC? Mild Gaming, Web Browsing, Invoicing
2) What's your budget? Id like to keep it at $2k Taxes/Shipping in with monitor
3) Where do you live? Grande Prairie, Alberta, Canada T8W2V3
4) What exact parts do you need for that budget? Case, CPU, Motherboard, CPU Cooler, HDD (maybe 2), Blu-ray Drive (reader is fine), GPU, RAM, PSU, monitor, keyboard, mouse.
5) If reusing any parts, what parts will you be reusing? I do have an Audigy X-FI 64MB PCI, new in box with face plate. I bought on sale for $99 when they were going for $350. Not sure if onboard is better now, or how it works with the new CPU/GPU. I can reuse MX500 Mouse if needed, and old keyboard if needed
6) Will you be overclocking? I wouldnt mind playing with it
7) What size monitor do you have and/or plan to have? Currently Dell 19" Monitor, 1280x1024
8) When do you plan on building/buying the PC? Was going to order right away, but was thinking of going 1155, so that pushes it back to march/april . No need for it tomorrow or anything.
9) What features do you need in a motherboard? Nothing, but was wanting to futureproof a bit, so SLI and Sata6
10) Do you already have a legit and reusable/transferable OS key/license? I think I have a win 7 Home Premium key left, if not I can buy a new copy, dont include that in price.
With that out of the way here is what I was wanting/thinking.
I want a fairly silent PC, that will game pretty well, but I dont need everything maxed. Im looking for a case (made a case thread in proper forum), without a window, and is clean looking. Here is the setup I was looking at:
- NZXT Phatom in white
- Enermax 800W PSU (i have had good luck with enermax, seem very high quality, though they are a bit pricy)
- Asus P8P67 Pro
- SB 2600+, might go 2500+ and OC a bit, Not sure if the added Cache even makes a real world diff.
- Maybe Spire Thermax Eclipse II, or Noctura D14 (to keep it cool and queit)
- 8GB (2x4GB) G. Skill DDR2133 (mobo supports it, figured it help with OC)
- WD Cavier 1TB 7200RPM Sata 6.0 (might go 2 smaller)
- Audigy X-Fi 64MB PCI (since I have it)
- Lite-on Blu-ray Reader with DVDRW. (again I have had good luck with them. My CDRW has lasted since 2000 with heavy useage, and I have went through 2 diff DVDRWs)
- EVGA GTX 570
- Logitech Performance Mouse (new one that will work on glass), and a G510 Keyboard
- Can resuse my monitor for now, but was planning on going with a decent 23" for gaming. 1080P minimum for blu-rays
Pretty Much I want a solid performer, that will last me a long time, and has a good performance vs price point on each item. The CPU cooler is to put a quieter fan on it, and keep it as quiet as possible.
So thanks in advance guys, I appreciate it.
Asus P4C800DLX
P4 3.0C
Cheap Case
Audigy 2 PCI
Lite-on CDRW
- Asus P8P67 Pro
- EVGA GTX 570
