MIRTBelGeran
- Apr 28, 2006
Been out of hardware for a bit and dont ahve the time to research myself.
I'm upgrading/building 2 systems and plan to reuse differant hardware in each. My end goal is to have 2 "almost" identical systems in the end.
#1 if for ME #2 is Bro in LAW
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing?
Both systems are primarily for Gaming
#1 $700-1000
#2 1000-$1300
3) Where do you live? TX
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
#1 = CPU, RAM, MB, Maybee Video, Maybee HDD,
#2 = Everything but the case and DVD
#1 Thermaltake Toughpower XT 850W, HDD 74GB WD Raptor Maybee, NV8800GT Maybee...
#2 DVD Drive and Case
6) Will you be overclocking? Mild OC To get my best value without adding expence of major cooling
7) What size monitor do you have and/or plan to have? Wide screen full HD resolution do not need this speced out as part of the build. 24+
8) When do you plan on building/buying the PC? 1st week in Feb buy build 2nd week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc. No special needs just stability with a mild OC
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit? Yes XPx32 but thinking of going to W7 x64
#1 $700-1000
#2 1000-$1300
