build help
Diesel-man3000
Hey guys i started my build without my hd and optical drive a week ago,and i closed it and its just been sitting there till i get my crap is it alright if it just sits there for a few weeks is it gonna hurt it.Also when i don't got the psu plugged in can i ground myself when tinkering inside the case by just touching the outside metal back?
it isnt going to hurt anything for it to just sit there with the power off. and yes its a good idea to ground yourself on some metal on the case before you go touching items on the inside of the case - usually a good idea to take off watches and other jewelry.........and make sure you dont drag your feet with socks on across the carpet before you go foolin around in there :D
