synaptical
- Aug 29, 2004
I've never installed an intel system before, heh. But this one is worse than I feared. I'm getting a completely black screen, no post, no nothing.
The only thing I've noticed is that with the hard drive plugged into the IDE port, it doesn't even spin up. If I unplug it, it spins up.
I reinstalled the processor (seems to be right, not 100% sure b/c it's weird with no pins), used only 1 stick of ram at a time, removed all PCI cards, video card, everything but the CPU and 1 stick of ram. I have two sticks, I tried each of them in both of the slots, same thing.
Oh yeah, I also removed the cmos battery, waited a few seconds, and then put it back in. The hard drive thing made me think the BIOS settings are wrong, but I can't even get a screen to come up to check.
Could the motherboard be DOA? It's this Gigabyte one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128357
The CPU is the Q6600, and the ram is g.skill 2GB each. Unless I"m overlooking something really easy it seems like it must either be the motherboard or the CPU, but I'm not sure what else to test. hope it's not the cpu, I got a slacr stepping and I'd like to keep it! Anything else I might be missing?
