Build help (Tiny Powerhouse)
Schwizzle
So, I was looking at the build tek syndicte did with the PC-TU 100 https://teksyndicate.com/videos/colugo-our-new-itx-gamingediting-rig-build-video and I was thinking of doing something very similar. My issue here is how good is the cooling? Is there anything I can do to make it more efficient? Perhaps I could turn the intake into a 120mm CPU radiator/exhaust and remove the 2.5 inch bays at the bottom, cut a hole and add some mesh for GPU airflow. Would any of that work? What are your thoughts? Would I need to do anything at all?
I would like to do some overclocking. I have this mindset that I have to have the best computer out of all of my friends, the issue now though is that they have i5's and gtx760's, I would be happy if I could get that performance (or better) in the smallest case possible. My budget is >$1000 it would mostly be for gaming maybe a little source filmmaker and possibly some streaming/YouTube stuff. This would all be new parts, nothing re-used. I would be more than happy to answer any further questions.
