actionshrimp
- Apr 18, 2009
Hey guys, I built my last PC around 4 years ago and am a bit out the loop now as to which parts are good and which aren't. I'd originally been looking at the Deskstar D350 and 450s here, then thought about doing my own build again.
-Web browsing/Multimedia, also Development, sometimes quite CPU-intenseive tasks so would like quite a fast processor - not sure if a quad core would really be necessary, but might go for it for longevity if I can fit it in the budget.
-If possible a fairly quiet system too.
-Don't play graphics intensive games (I use linux and can never be arsed to boot into windows), but I do have dual monitors (24" 1920x1200 and 19" 1280x1024) and would like desktop effects etc to behave smoothly - would mobo onboard graphics suffice for that these days avoiding the need for an additional video card?
£400-500 incl. Tax and shipping
3) Where do you live?
UK (usually buy parts off ebuyer.com)
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Motherboard, Case, RAM (4GB?), CPU, 1x1TB hard drive
-1x1TB Samsung SpinPoint F1 HD103UJ HD
-Antec "True Blue" PSU 480w (May need replacing - not sure)
-LG GDR-8164BL 16x52 DVD-ROM drive
-HP DVD640i DVD+/-RW
6) Will you be overclocking?
Probably not
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
-Planning to put a new 1TB drive with the existing 1TB drive into RAID-1, currently run a few disks on software RAID-5 with linux (wouldnt be doing this on the new system), but think it might be easier to set it up controlled by the mobo if I'm starting over again.
-2 LAN ports, have this on my existing setup and use it a lot more than I thought I would
-Fairly good onboard graphics with dual screen support if it's not worth getting an additional graphics card
10) Do you already have a legit and reusable/transferable OS key/license?
Yes, ubuntu.
Hopefully nothing here conflicts with itself too much. Would appreciate your input very much, particularly with regards to the motherboard, onboard graphics vs additional card, cases, and also whether or not I'll need a new PSU (don't mind spending a bit here if necessary).
Probably not
asap
Yes, ubuntu.
