- May 7, 2007
I didn't see your post, john. I tend to prefer xfs. I've found that xfs seems to disable the write barrier when I am running it in a VM, claiming that the write barrier check failed (for whatever reason.) That said, the couple of times I tried playing with ext4 I gave up - the write performance was abysmal, and I wasn't doing anything customized - a straight up install.
I'll go ahead and try out XFS on my next build and see how it compares. I've heard a lot of good things about it.
I never cared for ReiserFS, and Ext2/3/4 were always very stable, but they were lacking in performance.
