Build for Law Firm
FRAGMAN BOB
I just got called by a small lawfirm(5-6 PC's) that I've done work for before. Their "server", which is about 8 years old, has only a 20GB HD, is on the fritz. They use this to back-up all their word processing and other productivity files, and also run a few lightweight apps from (like a timeslip program to log hours). They want my help to spec out and set up their new server. They want to have a mirrored (RAID 1) setup to help prevent data losses.
Most of their PC's are XP SP3 with a couple on Vista. I am not sure if they would need an actual server, as that may be far in excess of what they will ask from it.
I was looking at the Precision Workstation line from Dell with 2 320gb drives in RAID 1. Running Windows 7 Professional.
Does anyone see any obvious problems that I am overlooking? Also would a high quality hot-swappable NAS serve them just as well? I am inexperienced when it comes to servers/business tech but am learning quickly. Thanks
What's the budget? 320GB drives aren't exactly the sweet spot for storage right now.
Wouldn't they want a server OS? Who manages/supports the system? Someone onsite? One of the lawyer's secretaries?
I'd say budget is around 1100, obviously lower is better as long as visible performance to them isn't impaired. I said 320gb because on dell's site it seems to be the price point as it is another $65 to jump to 500GB and also because after 8 years they are starting to approach the limit of the current 20GB of storage. Probably due to 80% of files being saved are word/excel files.
Maintenance will be split between the two lawyers, they maintain their current solution with updates, etc. Preferably the solution with the least maintenance is best.
And forgive my naivety but what would they gain (in simply file sharing and light application hosting) by having a Server OS?
I would suggest going with Windows Home Server with Athlon2 x4 build.
What you get is Centralized Backup, Health Monitoring of the other computers on the network, Shadow Copy, Headless Operation (No monitor or keyboard is required to manage the device) and Remote Access Gateway.
$65 will get you a whole other 500GB - 1TB HD. Get something from Dell (their cheapest) and stuff it with upgrades yourself.
A Windows Home server would probably work well for them as well. A PowerEdge starter server should be much cheaper than a precision. A dual core would suffice, since its just a file/backup server. You would only need a couple gigs of ram. If they're more computer savvy, they can run a distro of linux instead of windows and save some money.
//edit: sorry, didn't refresh before I posted, lol. shiro beat me to it.
Well if they've managed with a 20GB HDD up to this point they obviously don't need anything too elaborate, but being a law firm I would think reliability is a top priority so that's where you could spend some of the ~$1100 - a Dell server with a basic hardware RAID controller doing RAID 1 with some mid-size SATA or even small SAS drives should be within budget.
Are you sure it doesn't need to do anything other than file serving?
What sort of backup startegy are they currently using/planning?
Just a thought:
- I am sure you can get a server cheaper than $1K. I'll let someone suggest what models as I am not too familiar with current server/workstation models.
- Spend the extra cash for UPS if you dont have it already.
- For data protection, what about some remote back up/storage. You may want to consider this to make sure data is not lost due to fire, flood etc...
Go with a cheap Power Edge tower server with Server2008 Foundation edition. Same price as Win7 pro with all the perks of Server 2008
My build would look like a T110 with 2 gigs of ram a SAS 6\ir with as much disk space in RAID 1 that you can afford
Just a thought:
You need to be extremely careful with this, because the data on this server is private (attorney-client privilege), and this should be treated with the same sort of need for control as say medical data.
My suggestion would be to rent a safe deposit box and handle the backups themselves. Can the men maintaining this server be taught a backup process this complex?
I could see Shadow Copy being very beneficial for this size environment.
Has anyone successfully used Carbonite or Moxy for small business?
well over the years i have find that people are lazy. so on less they person. who mainly duty is i.t. don't look for it to be done right or at all.
