Friend is having issues registering for some reason, so she asked me to post this for her.
Primarily gaming, though also just your general usage.
Preferably under $1000, though I'm willing to jump up to $1200 if there's something that is just that much better. Shipping is not included, tax is.
3) Where do you live?
Minnesota
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
This would be built from scratch, so pretty much everything.
N/A
6) Will you be overclocking?
Not likely, or if I do, not extensively.
I currently have a 1280x1024 monitor, though I do intend to get a second widescreen monitor, probably around 22".
Within the next 8 months or so. I'd kind of like to buy things piece by piece based on my income (which is, for the first time in about 4 years stable), so whatever is least likely to need upgrading would likely be bought first.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
None of that really.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
I do not. I plan to get Win7 once I get closer to build time.
I would like to add that I have never actually built my own computer before. I have more than a few friends that can help me actually put it together, along with my dad, but I, myself, have never actually done it.
Because I went to school for graphic design, I've been rather comfortably using a MacBook Pro for the last 3 years. It works well enough for my gaming purposes right now (World of Warcraft mostly, and when it's released Diablo 3), but I'd like to actually be able to run the game (and any other games I pick up) with settings higher than low.
Minnesota
N/A
