Hello,
A family member of a friend of mine asked me to put together a computer for him. I was hoping to get some advice on the build. Here are the answers to the questions in the sticky and a list of parts that I was thinking of for the build:
He will use the computer mainly as an HTPC. He needs a computer that will support dual displays -- one display will function solely for watching movies/TV shows (HD content likely), and the other will be used mostly for web browsing.
He would like to keep the cost below $600, including tax and shipping, and excluding mail-in rebates.
3) Where do you live?
NYC.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
He needs everything except an OS, mouse/keyboard, and display.
Reusing nothing except for mouse/keyboard and displays.
6) Will you be overclocking?
Likely not.
7) What size monitor do you have or plan to have?
The display for watching movies is a 32" Samsung LCD, and the other display is small -- maybe 19"?
Within the next couple of weeks.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I cannot think of any features that he really needs -- certainly no RAID or XFire/SLI support. Knowing him, he might like to be able to record TV shows at some point.
Here is the list of parts that I came up with:
Intel Core 2 Duo E7200 Wolfdale 2.53GHz LGA 775 65W Dual-Core Processor Model BX80571E7200 - Retail ($119.99)
LIAN LI PC-A05B Black Aluminum ATX Mid Tower Computer Case - Retail ($80.00)
Western Digital Caviar SE WD800JB 80GB 7200 RPM IDE Ultra ATA100 Hard Drive - OEM ($36.99)
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM ($22.99)
Noctua NH-U9B 92mm SSO CPU Cooler - Retail ($49.99)
GIGABYTE GA-E7AUM-DS2H LGA 775 NVIDIA GeForce 9400 HDMI Micro ATX Intel Motherboard - Retail ($134.99)
PC Power & Cooling Silencer PPCS500 500W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail ($69.99)
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ - Retail ($39.99)
Total Cost: $554.93
Here is a link: http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=7721374
I do not know if the motherboard will allow for watching HD video on one display while browsing on another display. To cut costs, I was considering dropping the E7200 for the E5200 and maybe just using the stock heatsink. I also might replace the 80 GB hard drive with something considerably bigger. I was thinking that he could start with a smaller HD for his OS and software and add something later for video. Any thoughts?
Thanks a lot.
NYC.
Likely not.
Total Cost: $554.93
Thanks a lot.
