dark_phantom36
- Jan 11, 2003
Ok. I'm wanting to put together a dedicated router/firewall box. I'm also planning on using one of the 'nix based dedicated firewall/router distributions.
Requirements:
Small - Probably something on an mATX board or some form of embedded solution (not familiar with those at all)
Inexpensive - Definitely less than 100 dollars
The problem:
If I go the PC route, I don't have a case for it yet, which will take up most of the budget.
Any suggestions?
If it isn't possible to fit the budget with a decent case, I can get a dinky mid tower from somewhere(my room) for free or another to use until I spot something small that I like at a later time.
For other hardware, I was thinking of a low end athlonxp or an athlonxp mobile with an mATX board, integrated video and 512mb of RAM.
Couldn't this be run without any hard disk if I used a USB drive? If so, would I need more RAM (since I wouldn't have any swap space because my spare USB drive is 512mb)?
Also, this would probably have at most 5 computers going through it for 99% of the time. Every once in a while, that could hit 10 for a LAN.
Thanks in advance!
Requirements:
The problem:
Any suggestions?
Thanks in advance!
