Benzino
- Mar 3, 2005
I'm looking into upgrading my aging Socket 478 system. I have a case, hard drive, dvd-burner, and speakers I plan on using. Below is what I selected from Newegg. This would be for medium gaming (BF2, CS:S, F.E.A.R., H2, UT2004, Far Cry, NFS:MW) I'm not interested in any newer games, maybe UTIII at the most.
I can tell everyone right off the bat I don't need Quad-core and would be hard pressed for Crossfire/SLI. I would be running Windows XP Pro. I would like to keep this around $850 as that's as far as I can stretch my budget.
Motherboard: Asus P5Q Pro
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
Processor: Intel Core 2 Duo E8400 Wolfsdale
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
RAM: 4 GB OCZ Reaper HPC Edition (DDR2 800)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227267
Video Card: Sapphire Radeon HD 4850 512 MB 256 bit GDDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102770
Power Suppy: Rosewill 550 watt ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182017
Sound Card: HT Omega Striker
http://www.newegg.com/Product/Product.aspx?Item=N82E16829271001
A few afterthoughts: Will the PSU be sufficient? Should I get aftermarket cooling for the CPU? Thanks!
