Build Critique v2.0 ;)
skrypts
These things are popping up like crazy aren't they? Anyways... it all looks good to me this will probably be my final decision unless [H] says otherwise. Hopefully it all fits and works flawlessly.
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600
Tuniq Tower 120 P4 & K8 CPU Cooler
Intel BOXD975XBX2KR Socket T (LGA 775) Intel 975X ATX Intel Motherboard
CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X2048-8500C5D
eVGA 768-P2-N831-AR GeForce 8800GTX 768MB GDDR3 PCI Express x16 HDCP Video Card
CORSAIR CMPSU-620HX ATX12V v2.2 and EPS12V 2.91 620W Power Supply
Western Digital Raptor WD1500ADFD 150GB 10,000 RPM Serial ATA150 Hard Drive
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive
Creative 70SB046A00000 7.1 Channels PCI Interface Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series
LG 18X DVD±R Super-Multi DVD Burner With 12X DVD-RAM Write Black IDE Model GSAH22N-BK
Microsoft Windows XP Home Sp2b 1pk w/Upgrade Coupon for Vista
LIAN LI PC-V1100BPlus II Black Aluminum ATX Mid Tower Computer Case
So that's it. Does anyone forsee any problems with the components I selected? Will the HSF fit on the motherboard without problems and inside that case? Will the power supply cords be long enough in this case?
Once again, thanks in advance for any input, I appreciate it!
Good luck with the build. I'm wondering why you went with a crossfire board but an nVIDIA vidcard? For the price of that ram, I would have gone with Crucial Ballistix sticks instead.
