Build almost done! one final step
Ezekiel33
Gaming, Photoshop, Web Design/browsing, I'll also run both Vista 64 and Xp 32
1300 canadian
3)Where do you live?
Montreal/Quebec/Canada
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I need the following :
CPU
RAM
Mother Board
Video Card
Dvd/cd Burner/reader
Hard Drive
PSU
None
6) Will you be overclocking?
Yes I will - CPU
7) What size monitor do you have or plan to have?
I'm actually using Samsung SyncMaster 226bw (22")
April
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Going for 1 Video Card
10) Do you already have a legit and reusable/transferable OS key/license?
yes I do, for both XP and Vista
Ok so here's my actual build :
CPU Intel Core i7 920
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819115202
Motherboards :
Asus - http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131359 ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard
Asus - http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131365 ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX
Evga - http://www.newegg.ca/Product/Product.aspx?Item=N82E16813188039 EVGA 132-BL-E758-A1 LGA 1366 Intel X58
Evga - http://www.newegg.ca/Product/Product.aspx?Item=N82E16813188046 EVGA 132-BL-E758-TR LGA 1366 Intel X58
Gigabyte - http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128374 GIGABYTE GA-EX58-UD4P LGA 1366 Intel X58
Gigabyte - http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128362 GIGABYTE GA-EX58-UD5 LGA 1366 Intel X58
Ram OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820227381
Cooling ASUS Triton 81 92mm EBR CPU Cooler
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835101030
Cd/Dvd LG Black 22X (CAV)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16827136152
PSU CORSAIR CMPSU-750TX 750W ATX12V
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817139006
Hard drive Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136319
Graphic Card EVGA 512-P3-N871-AR GeForce 9800 GTX(G92) 512MB
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814130339
I need help for the mother board.. I really dont know what to choose between the ones Ive mentionned. I'll overclock the cpu and will be using only 1 video card.. Anyone can tell me whats the best motherboard for me?
thanks!
Please list out the parts names in addition to their links.
I'd explain more, but I don't really have the time. ;)
The Asus P6T vanilla fits your needs and is the cheapest, so go for that.
Cheaper RAM alternatives:
$167 - mushkin 6GB (3x2GB) DDR3-1600 998659 9-9-9-24 1.5v-1.6v
$213 - OCZ XMP 6GB (3x2GB) DDR3-1600 OCZ3X1600LV6GK 8-8-8-24 1.65v
For a 22", go for an HD4850, HD4870 512MB or 1GB, or the GTX260.
