Build advice.
chaos952
Mainly gaming and audio recording/music production.
$3,500, does not include tax/shipping.
Takoma Park, MD, USA.
Mobo, CPU, RAM, Storage drives, CD/DVD burner, sound card, video card, case, PSU, monitor, wireless adapter, and OS.
Keyboard and mouse.
6) Will you be overclocking?
No.
2560 x 1600. (30")
Hopefully by the end of this month, but I can wait a little longer if needed, as I am aware that Ivy Bridge processors and Z77 boards are right around the corner.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0, SATA 6Gb/s, UEFI. SLI support would be nice to have, but isn't necessary.
No.
And now for the build... Everything will be purchased from Newegg unless otherwise noted.
Motherboard: Gigabyte Z77X-UD3H - $160
CPU: Intel Core i7 3770 - $320
CPU Cooler: CM Hyper 212 Plus - $27
RAM: G.Skill Ripjaws Series 4x4GB DDR3 1600 - $90
Storage: 1 Crucial M4 256GB SSD, 1 WD1002FAEX 1TB HDD - $250/$140
CD/DVD: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - $20
Audio: HT | Omega Claro Halo - $200
Video: eVGA GTX 680 - $500
Case: Corsair Carbide Series 300R - $75 @ microcenter
PSU: Corsair HX750 - $150
Extra Case Fans: 4x Scythe Slipstream SL1225L12M 120mm - $44
Monitor: HP ZR30w - $1,180
Wireless Adapter: TP-LINK TL-WN722N - $18
OS: Windows 7 Home Premium - $100
Total: $3,338
Have at it.
Regardless of whether you go with a Z68 or Z77/79 board, don't go with AsRock. AsRock boards have one- to two-year warranties whereas other boards (from Gigabyte, Asus, and MSI) have three-year warranties.
Why are you going with multiple SSDs? Regardless, the Corsair Force 3 isn't the best choice around. I recommend going with either the Crucial M4 or Samsung 830 series SSDs. The Intel 510/520 SSDs are also good, but they're considerably more expensive.
I wouldn't recommend the Corsair Vengeance RAM as the tall heatspreaders may interfere with the CPU cooler. Go with the Vengeance LP, Corsair XMS3, or a different brand/model that uses low-profile heatspreaders.
What does the Netgear wireless adapter offer that cheaper-yet-equally-capable adapters don't?
Bumping for Mobo/processor change, wireless adapter change, and also the fact that I am planning to order parts this week. I noticed Tiger Direct has a (Galaxy) GTX 680 in stock at the time of this post, but how legit is that? I want to call BS on that, lol.
That hard drive isn't a good choice considering that the significantly faster Samsung costs less:
$120 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
With the exception of the sound card (don't know much about them) and hard drive, setup looks fine to me.
