LAN parties, Folding, guest use possibly
Not really sure, more of a feeler of what I should look out for(see blow), and yes
3) Where do you live?
FL
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is
not a valid answer. Please list out all the parts you'll need.
Mobo/PSU/HSF(air cooling)
Q9450, 4x1gb OCZ Platinum(4-4-4 @ 2.1v), PNY 9800GTX XLR8, WD 320GB Caviar Blue, Case(i'm building it myself)
6) Will you be overclocking?
Yes
Will use either: 19" 1440x900, or my 24" 1920x1080(depending on how far it is)
6-8 months(after school starts for the year)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
SLI preferably, and mATX if possible(doubt it, couldnt find anything myself), but SLI is a must because in the best case scenario ill end up with SLI'd 260's
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, will have Win 7 Pro x64
I'm pretty much looking to get my lan rig going, picked up the Q9450/ram/hdd on the cheap(~$140, and it was all never OC'd, kept in a house that is always at 78 F), the case i'm building on my own hopefully as a side project(hence why mobo size isnt very needed)
On the PSU I would love to have a full modular design(i'm thinking 550-650w right?)
as i said, this thread is pretty much a feeler....to see what I should look for(i've got no problem ordering refurb parts for this, since it is pretty much a lan/backup rig)
FL
Yes
