The PC that I built 3 years ago seems to be giving me problems so I have decided to build a new system.
My current system consists of:
Intel i5-750
EVGA P55 SLI MB
G.Skill 8G Mem
Galaxy Factory overclocked GTX 480 1.5GB
1080p LG 32LD450 TV Monitor
SD for OS
Couple of HD for steam and pics/video storage
I will be using my new build for Gaming/Photo Editing and some video editing. I am not a professional photographer/videographer. Just looking for good performance for home use. However I do own a Nikon D800E and with its 36MP, it does slow down Lightroom.
I am also planning to use the 1080p LG monitor for now until Dell has the bugs resolved on its new 30 inch monitor. So until then I plan on using my GTX 480 which seems to do fine on the 1080p resolution. Once I upgrade to higher resolution on the dell, I can upgrade the Vdieo card as well.
so basically I am looking for a system which I can use right now but also one which is upgrade ready for the new Dell 20 inch monitor and a high end graphics card at a later date.
Gaming/Photoediting/some video editing and Web browsing
Budget is somewhat flexible. But lets start off with about $600-1000 range. I do no want to spend more if I do not have to.
Boston, MA
CPU, CPU Cooler, MB, Memory, SSD, HDD, PSU, Case
I plan on resuing the 1080p 32 inch TV monitor and the GPU GTX 480 factory overclocked for now. As I said, I will be upgrading these two parts once Dell has the bugs sorted out on its new 30 inch monitor. I was also considering resuing my XFX Black Edition 750 watt PSU which is a very good quality PSU, but I have been using it for about 3 years now. Perhaps not advisable?
GPU - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6680898
Monitor - http://www.amazon.com/LG-32LD450-32-Inch-1080p-HDTV/dp/B0039RRCJ8/ref=cm_cr_pr_product_top
PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817207003
6) Will you be overclocking?
No.
1080p 32 inch LG TV/monitor. Will use it for now but later upgrade to a higher res monitor.
Asap? Within the next month or two at the very least? Unless I there is a high incentive in waiting because of a new release?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0, STA 6Gb/s for sure. eSATA and SLi support would be nice but not necessary.
Yes I do. I have a legit Win 7 64 bit software/key.
Intel i5-750
EVGA P55 SLI MB
G.Skill 8G Mem
SD for OS
Boston, MA
No.
