Gaming (a wide mix, including mainstream titles), Software Development, Coding, and some image production work.
Around $1,500 USD, though less is always a plus
United States. Lancaster, PA
Part of this will be answered by how much I can reuse. At first glance, I know (I think) I will need CPU, Motherboard, GPU, and SSD.
Current Setup below. I would like to reuse some of the parts if possible. I believe the memory and PSU should be usable. Not sure about the case.
Case: Rosewill CHALLENGER Black Gaming ATX Mid Tower
CPU: Intel Core i5-2500K Sandy Bridge Quad-Core 3.3GHz (Stock Cooler)
Board: ASRock Z68 Extreme3 Gen3
Memory: G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
SSD: Corsair Force3 90GB
GPU: MSI N560GTX-TI Twin Frozr II/OC GeForce GTX 560 Ti (Fermi) 1GB 256-Bit GDDR5
PSU: COUGAR SX850 COUGAR-SX850 850W ATX12V / EPS12V SLI Ready CrossFire Ready
6) Will you be overclocking?
I hope so, so I assume a non-stock cooler will be required.
Asus 24". Max Res: 1920 x 1080... I am trying to decide if I want to add 2 more of these monitors or replace with a larger single monitor. Note: This is not part of the budget above. http://www.newegg.com/Product/Product.aspx?Item=N82E16824236153
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0. I may do RAID, not decided yet.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I do. 64bit.
EDIT: Hit post too early.
Here are some of the parts I am looking to upgrade so far.
CPU: Intel i7-4790K Haswell Quad Core 4.0GHz http://www.newegg.com/Product/Product.aspx?Item=N82E16819117369
Motherboard: GIGABYTE GA-Z97X-UD5H http://www.newegg.com/Product/Product.aspx?Item=N82E16813128707
GPU: MSI GTX 970 Gaming 4g http://www.newegg.com/Product/Product.aspx?Item=N82E16814127832
SSD: Samsung 840 EVO 500GB http://www.newegg.com/Product/Product.aspx?Item=N82E16820147249
My questions are this:
1. Does the planned part replacement look like a good building block for the future or does anyone have any better recommendations?
2. Any reason I cannot reuse my Memory for this build? How about the power supply?
3. Will these new components fit into the existing case or should I order a new one?
4. Any good recommendations for a CPU cooler?
5. Display. Should I add 2 more of the ASUS 24" 1920x1080 or should I replace all together?
6. If my budget allows, I was considering buying a second GPU of the same listed above. Is this worth the money or overkill right now?
Any other information is greatly appreciated. Thank you
ASAP
I do. 64bit.
