Build advice - I'm about to pull the trigger
HunterDC
I've been taking a long time to put together my first build but i'm finally ready to make the purchase. There have been a few delays but I think I finally have everything selected. I just want to make sure that all these parts will function well together. Is there anything missing or something that wont work with the other components? Here is my build and thanks for the advice.
(These are the exact components I have in my cart):
Motherboard - P5W DH Deluxe
Processor - E6600
Memory - Buffalo FireStix DDR2-800 2x1GB
Video Card - 8800 GTS 640MB
Case - Lian LI PC-7B plus II ATX Mid-tower case
PSU - Rosewill RP600V2-S-SL 600W
Hard Drive - Seagate Barracuda 7200.10 750GB
Keyboard/Mouse - Logitech MX3000 Keyboard & Mouse
DVD Burner - LITE-ON 20x DVD Burner w Lightscribe
Sound Card - bluegears b-Enspirer 7.1 Channel Sound Card
Speakers - Logitech X-530 70 watts RMS 5.1 Speakers
OS - Windows Vista
Looks good with the excpetion of the PSU imo.
I think you should spend alittle more and get yourself a better PSU.
Something like: Corsair HX 520 or SeaSonic S12 Energy Plus SS-550HT or ENERMAX Liberty ELT500AWT
Those are all good choices, IMO, and provide more than adequate juice for you for overclocking and some future headroom. More importantly, they are good stable PSU's.
The Corsair would probably be your best bet all around. But the Enermax at $25 less is a good buy.
You might also consider getting an aftermarket CPU cooler now if you plan on overclocking. No need to install the stock cooler just to take it back off in a month or so.
Good luck, and congrats on your new system.
Don't go with the Rosewill Power supply you chose. Any of the power supplies that PredatorJ mentioned will be perfect for you.
No thoughts on these two PSUs? I want to make sure they will be adequate for my system.
And as for the rest of my components, they will all work together? Since its my first build, I'm concerned about making sure they will all connect properly, work together, etc. I'd appreciate confirmation that I'm doing everything right from those of you who have experience,
Thanks
The ss-550ht is the better choice of those 2 IMO. 41amps on the 12v rail (total). Solid unit.That or the Corsair I mentioned earlier (There the same price) Will do you justice.
The rest of your build is fine.
Good luck.
Yeah get the SS 550, or the Corsair 520.
Oh, and I highly recommend the logitech G7 wireless. I love it :D.
What Vista are you getting?
Would it be worth it for me to go with the OEM version? Its a lot cheaper but I'm not sure what is left out and I feel like I might need everything that comes with the retail version. What do you guys think, which should I get?
With Retail you aren't restricted to one set of hardware for the install. You're also paying for Microsoft support. With OEM, the install is tied to the hardware and you typically cannot install it on another machine. You could probably coax Microsoft into letting you though. You also have to get support from the person who built the computer, or yourself in this case.
I'd say OEM. Retail is about twice as much, so if you were to want Vista on another machine, it'd cost the same to buy another OEM copy anyway.
I bought it all yesterday and it should arrive next week. The only piece I didnt order yet is the memory, the FireStix are OOS and should be in on Monday so i'll grab those then (hopefully they will still be sending D9s).
Thanks for all the advice (in this thread and my other earlier questions). I'll keep you posted on how things go -- i'll certainly have a lot of questions as this is my first build.
[H]unter
