Build advice for friend
tommy13
Hello, I recently got help here picking some parts for an upgrade of mine. So I am back and seeking help for my friend who needs a new build.
He and his wife are not power users at all. They only need to run Quickbooks for his business and Photoshop for her. Does not need a video card at all, just onboard. Thank you so much.
Photoshop, Quickbooks, Web Browsing.
$900 Tax and shipping included, I have Amazon Prime. Microcenter about a hour away. Not really looking towards that.
Temecula, CA. USA.
CPU, MOBO, Case, PSU, RAM, DVD, SSD, keyboard and mouse.
He has a 19" monitor that he wants to keep.
6) Will you be overclocking?
No, doubt it.
I believe it is 1600x900 or something like that. He's not gaming at all.
This week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3, SATA 6, Onboard Video(Main GPU)
No, need windows 8.1 64-bit.
What I was thinking:
i5 4670k
8GB G Skill
Seasonic 550w
Corsair 300R
Samsung EVO 250GB
Windows 8.1
Random DVD Burner.
Not sure which motherboard to get for them.
I'll probably just get them a logitech combo for mouse/keyboard.
Thank you in advance.
I recommend the following instead:
$185 - Intel Core i5 4430
$68 - MSI B85M-G43
$130 - Kingston HyperX blu 2x8GB DDR3 1600 RAM
$140 - Samsung 840 EVO 250GB SSD
$59 - Seagate Barracuda 1TB HDD
$15 - Lite-On iHAS124-04 SATA DVD burner (includes $5 instant discount promo code EMCPGHB99, expires 4/3)
$86 - Seasonic SSR-550RM 550W modular power supply
$98 - Microsoft Windows 8.1 64-bit OEM DVD
$17 - Logitech Desktop MK120 wired keyboard/mouse combo
$754 - Total before taxes
I reused your choices in OS, SSD, and PSU but swapped out the i5-4670K for the i5-4430. You're not overclocking nor do you need the i5-4670K for web browsing and Quickbooks.
However, I increased the RAM amount as a way to improve Photoshop performance. (In the future, you should also consider another, smaller capacity SSD to use as a swap disk in Photoshop.) I also added a hard drive so you have space to offload non-essential programs and other files. (SSDs perform better when they're under 50% capacity.)
The MSI B85M-G43 met your needs in sticky question 9 without costing an arm or a leg. The Lite-On iHAS124-04 was the cheapest DVD burner I could find. (You shouldn't have to pay more than $25 shipped for a decent DVD burner.) I went with the cheapest Logitech combo Amazon had available, but I also found the cheapest Logitech wireless combo.
I believe that the Corsair 300R may be too much case for your friends' needs. I like the Fractal Design Core 1000 as an alternative, but you'll run into some cable management issues even with the use of a modular power supply. I'll defer the case recommendation to you.
